Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 10-28-2013, 07:57 PM
John90290 John90290 is offline
Vehicle: 1999 Ram 2500 4x4 v10
Trim Level: Lariat
Color: Green
John90290 is on a distinguished road
Default V10 sounds bad. Lots of knock:(
She doesn't sound good. 1500 to 2500 in neutral and or drive, it knocks a lot. Hoping it was the purge valve but not a chance. Exhaust leak at the manifold?
Figure if it was rod or such it would make the noise throughout the power band?
All other aspects of truck are great. Idles perfect. Get over 8 around town and 10 highway. Oil is clean. She drinks coolant though but I can smell the heater core leak. It's California so I'm not in a rush to peel back the dash.
Take a listen if u have a chance.
Thanks in advance for the help.
1999 2500 4x4 v10 auto tranny 178k
Old 10-29-2013, 12:27 PM
Trim Level: Lariat
Color: Green
Default Cracked Flex Plate
Found this video on you tube while waiting for a response, identical to mine.
ordered a stehiscope to make sure.
Old 12-29-2013, 10:26 PM
Cheatham Cheatham is offline
Vehicle: 2012
Color: Grey
Rep:17
Cheatham is on a distinguished road
that sounds like rod knocking
Old 06-14-2014, 01:18 PM
M. R. Wirick M. R. Wirick is offline
Vehicle: 1999 V-10 2500 4X4
M. R. Wirick is on a distinguished road
John,
What was the fix? I have a 1999 V-10 that just started doing the same thing. I changed the DCP Valve, no fix. I'm looking at the flex plate right now. Thanks!
MW
Old 06-14-2014, 05:48 PM
Keith1 Keith1 is offline
Vehicle: 1999 Dodge Ram2500
Keith1 is on a distinguished road
Not sure what the OP found but sure sounds like a rod to me. If your checking one out check the oil for foreign partials. Just rub some between your fingers, if it feel anything but smooth then beware.
Old 06-24-2014, 08:45 PM
Default V-10 Noise
Thank Kieth! Oil (feels) good I guess I should pull the pan and take a look.
Old 06-24-2014, 09:16 PM
My noise sounds like valves "floating" at @ 2100 RPM to me. I just had a guy tell me it may be my torque converter, as the noise seems to coming from the bottom end? The truck pulls hard and the noise doesnt start untill shifting or if im real easy on the throttle it will start. On start-up I have a little clatter untill the lifters pump-up. Thanks to you all again for any help!
knocking, purge cycle, rod, v10
