Rear Axle trashed - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-29-2013, 10:09 AM
axehandle axehandle is offline
Vehicle: 2011 ram 1500 laramie
Trim Level: laramie
axehandle is on a distinguished road
Default Rear Axle trashed
hi, does anyone know if a 2012 rear axle will fit a 2010 1500
pinon nut came of mine and trashed everything (missed the recall )
all i can get hold of is a 2012 model from the breakers yard,
so please anyone ?
Old 10-29-2013, 10:08 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
If your truck is listed under the recall Chrysler will replace the axle. Check with a dealer. As for your question, 4th rear axles (9.25) are all the same, just make sure you get the correct gear ratio and check to see if it has a limited slip or not.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 11-04-2013, 01:38 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:782
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
5 year 100000 mile warranty should take care of this.
Old 11-04-2013, 05:10 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:368
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
call a few dealers,. even if you miss the recall, even if your warranty is out, they will take care of it
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover, powerstop brake kit.
Old 11-04-2013, 05:50 PM
Rep:2929
the Ram rear differentials in the 2011 - 2014 Model Year were made by ZF
the rear differentials made earlier were made by AAM
Old 11-04-2013, 06:27 PM
paul2112 paul2112 is offline
Vehicle: 2010 Ram
Color: Rugged Brown
Rep:13
paul2112 is on a distinguished road
Default Recall
Just got my second recall letter in the mail for this
Old 11-04-2013, 06:47 PM
Rep:2929
I just noticed where Axehandle lives, that could be a major issue
It may be best to buy that whole rear end assembled & swap it out, that is if the measurements are close to the same
If the drive shaft Yoke needs to be changed, that is fairly easy to do
Old 11-04-2013, 08:15 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Good luck and please keep us updated....I would like to think that the dealer would look after this for you due to a recall....Not everyone received the recall notice.......I would call them first and feel them out.....
Old 11-04-2013, 08:23 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Question
I just got my second recall notice for this, apparently they now have the parts. I'm a bit apprehensive as I've had no problems, even dropped my drive shaft and had a look and put some lock tight on the exposed threads. I have also replaced the diff fluid with Amsoil synthetic gear oil. If they make things worse I will be extremely pissed. Really not sure what to do at this point. axehandle, any warning or fluid leaks before this happened to your RAM and what is your mileage?
sales@revelperformance.com
Old 11-05-2013, 01:55 PM
Rep:782
wonder if they get the same warranty we get.
