Old 10-29-2013, 11:28 PM
97mopar318 97mopar318 is offline
Vehicle: 1997 Dodge Ram
97mopar318 is on a distinguished road
Default temperature gauge giving faulty reading, to high!
This is my first post, I usually start by giving info about myself but I am out of ideas and this problem still exist.
I am having a problem with my coolant temperature gauge in my 97 dodge ram 4x4 with a 5.2. My gauge reads that the truck is running at the last 0 in 200 about 3/4 of the gauge, but the truck is not running hot at all. I have replaced everything with brand new parts this has been a problem when I bought the truck 4 years ago. I have installed new water pump, radiator, water outlet, thermostat 3 times 2 were 180 degree and 1 195 degree, new hoses, radiator cap and the heater core was replaced by a local shop by the previous owner. Also I have replaced the coolant temp sensor for the computer as well as the temp switch for the gauge 2 times. The gauge reads currently with the 195 thermostat about 230 but when checked by a hand held temp gun shows the motor is at about 185-197 and with a scan tool the computer shows anywhere between 189-192. As instructed by a local shop I checked the gauge by unplugging it and it dropped to 0 as if the key was off then grounded the wire and it pegs out past the gauge numbers. I also dropped it off at the shop and they said everything seems to be functioning correctly but that it just reads hot. Everything is original to the truck accept the fore mentioned parts and the gauge cluster was replaced with one out of an identical 96 ram, the gauge was reading wrong with the original cluster as well.
Old 05-23-2014, 07:46 PM
dubrick211997 dubrick211997 is offline
Vehicle: 1997 Dodge Ram 1500
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
dubrick211997 is on a distinguished road
Did you ever figure out your problem? I have the same issue...!
Old 06-15-2014, 08:07 PM
ncdodgeman90 ncdodgeman90 is offline
Vehicle: 1996 dodge ram
Color: green/silver
ncdodgeman90 is on a distinguished road
Default finnaly somebody with same issue
Hey bud did you figure out the problem i have the same exact problem any info would be awesome thanks
Old 06-17-2014, 10:27 PM
Lazarus Truck Lazarus Truck is offline
Rep:190
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
I have this issue also, after replacing the one-wire sensor. I used sealant, or tape on it. Should it have been installed bare, as it was threaded with an NPT tapered pipe thread, that usually does not require sealant? Could my use of sealant changed the resistance of the sender? Mine was steady at 200 deg. Now steady at 230 deg.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 06-18-2014, 08:42 PM
Color: green/silver
Hey lazarus truck have you got any info from anybody about this gauge problem cause i cant figure it out to save my life and im about to go on a 1600 mile trip with my rig and i dont want to be guessing my temp thanks man
Old 06-20-2014, 11:22 PM
Rep:190
I used an AZ brand of sensor, so I dont know if it is crap or what-not. I usually buy good stuff on Amazon. From all indications, the motor is still running normally. I have an IR thermometer and the readings from it are much lower than the gauge.
Old 06-21-2014, 08:12 PM
Color: green/silver
Default no go on the thread sealant
Lazarus i know what your problem is its the thread sealant i had to take a little bit of time to think about your issue if that thread sealant is there then the sender can not ground itself and the sender has to be grounded to send a correct signal to the gaug so if you pull the sender back out and remove that sealant then im pretty sure you will be back to normal on the gauge
Old 06-21-2014, 10:29 PM
Rep:190
Thanks NC, I'll try that as soon as I finish the rocker replacement this week!
Old 06-21-2014, 10:43 PM
Color: green/silver
No problem just keep me posted i figured out my problem to my gauge was shorted out when i changed my heater core hoses so I'm installing a aftermarket gauge with a piller pod tomorrow
coolant gauge malfunction
