Am I going to set my truck on fire? (wiring question) - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 10-31-2013, 08:59 AM
Kris319 Kris319 is offline
Vehicle: 2014 Ram 1500
Trim Level: Sport Crew Cab
Rep:29
Kris319 is on a distinguished road
Originally Posted by Kamanhart View Post
absolutely man i def wanna see some pictures of it when you get it done it should look pretty sweet with that many leds
I'll definitely post some pictures. I ordered the leds from China so it will probably be two weeks before they arrive.
Old 10-31-2013, 11:45 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Originally Posted by Kris319 View Post
This is why I love forums
Thanks to the input, I'll more than likely wire it to a switch and run it through the firewall.
if you look at the entry point of the firewall where all your wiring goes in, there is a rubber gasket where all the wires pass, just under the wire bundle in the rubber gasket there is a nipple there, cut off the tip of it and you now have a hole to pass your wire to a switch on your dash.
Old 11-01-2013, 11:55 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I'm looking to do this hood scoop led mod. The Hid kit I'm using on my fogs does not utilize the passenger side oem plug so I was hoping I could use it to power this led disaster. Below is a diagram (be gentle I did it on my tablet) of the wiring I have in mind.
My questions are:
  1. Is this possible/safe?
  2. What gauge wire should I use?
  3. Is there anything else I need/should use like a relay?
You have a lot of variables here so it is hard to answer.
There is a good post that you can follow, so I hope this helps.
http://www.ramforumz.com/showthread.php?t=135333
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-01-2013, 12:42 PM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I agree pretty much with everyone above. I tend to go over kill when it comes to circuit protection though. Due to my screw up, I melted down the entire wiring harness in a '91 Cavalier because I didn't install a relay or an in line fuse.... it wasn't pretty.
I know try to put a relay on pretty much anything that is going to handle more than 1-2 LEDs in any project that I take on. I especially do this if I'm using some other circuit as a "trigger" and not just as a convenient place to tap for power. I think the need for a fuse is fairly self evident.
I think that your set up pictured above will work just fine, though I'd add both an inline fuse and some sort of relay for the reasons that I just stated.
Just my opinion.
Good Luck
Exco
Bill
Old 11-04-2013, 12:12 PM
Rep:29
Just my opinion.
Good Luck
Exco
I actually have an extra relay and fuse laying around from my hid installation so I guess I just found a use for them
Old 11-05-2013, 10:26 PM
Rep:29
After doing some research I came across this wireless switch which should work perfect and eliminate me having to mount something in my interior.
http://www.amazon.com/gp/product/B00...A33TCMZEAWOM9U
I plan on feeding power directly from the battery with an inline fuse and grounding it to a screw on my hood. This should work without any issues, correct?
