Old 10-31-2013, 02:10 PM
fxnytro17 fxnytro17 is offline
Vehicle: 2013 1500 Quad Cab
fxnytro17 is on a distinguished road
Default Headlights
I know theirs a lot of dispute and posts about these new projector headlight but as of a lot of you, mine are also fogged up.
I went to the local dealer and he said hes going to order me two new ones.
I have one problem, I have HID bulbs and ballasts put in. To do this with the high beam I had to drill a 1 1/4" hole in the back. It looks professional because it did come with a perfect fitting seal.
Anybody think that they wont replace it once they see that their are holes in the back? I think im going to have a problem...
Old 10-31-2013, 02:18 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:674
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
They may not notice if like you said the seal looks professional. Besides, there isn't really anything you can do about it now if they are going to notice. It seems like they were pretty agreeable when you went there in the first place, so I doubt they're going to tell you that they won't install parts they ordered specifically for you because of it.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 10-31-2013, 02:34 PM
Asur Asur is offline
Vehicle: .
Rep:4373
I would put the halogen bulbs back in and remove the HID's, I don't know what kit you have, what type of seal was there, but the hole and seal may be the culprit also to your humidity issue in the head lamp, if they see you made a hole, they might just charge you for them and with labor also, If you physically modified the headlamp you are sole responsible for it, if no modifications were done, then it could be factory defect. Not sure how this will pan out but keep us informed.
Old 10-31-2013, 02:47 PM
jaray jaray is offline
Trim Level: Sport Crew
Rep:197
jaray has a spectacular aura aboutjaray has a spectacular aura about
Makes me think twice now as I'm considering what path I want to go with HID's from RetroShop. Either send the OE's away for the projector install, or purchase a complete new OEM set of headlights from them already modded. Hella expensive with the complete new light option, but then no worries about touching mine.
Gibson Cat-back exhaust w/black tips, S&B CAI, MGP caliper covers, Recon LED 3rd brake light, Bilstein 5100's, Daystar 1" rear coil spacers, Weathertech floor liners, Westin Ultimate series bull bar, Dee Zee Tailgate Assist, Mopar T- Handle, Kicker speaker upgrade
Old 10-31-2013, 04:26 PM
Well really the hole is in the back cover and not the actual headlight itself.
And my lights were fogging up sense the day I bought it before I put the HIDs in.
Old 10-31-2013, 04:39 PM
Rep:197
I wonder if the back cover can be changed? Does it look removable? I'm doubting we'd ever be able to get our hands on it anyway though if it was.
Old 10-31-2013, 05:02 PM
Rep:674
The condensation thing is a known issue on vehicles with LEDs. Something to do with not enough heat to evaporate it through the moisture barrier when they're running or something like that. My truck only has incandescents and I've had no problems so I haven't looked that far into the LED condensation issue.
My point is though, the dealer likely won't take issue with it if they are aware of it happening on other rams with LEDs.
Thunderhorse:
Colt:
Old 10-31-2013, 06:28 PM
I get what your saying thunderhorse but I asked the dealer and he said he'd never Hurd of it! I couldn't believe that but that's what he said
Old 11-01-2013, 08:15 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
I purchased complete dual headlight setup converted to projectors from Retroshop and I do not regret spending the money. The lights are IMO the first upgrade that should be done to the Ram.
Old 11-01-2013, 11:08 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I would go to the junk yard and get replacement covers where you drilled the holes. I have quad lights and HID low beam lights (we may have different lights so this my not apply) Also remove the HID kit so everything will be back to stock. JMO.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
