Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 10-31-2013, 10:55 PM
Deereman39's Avatar
Deereman39 Deereman39 is offline
Vehicle: 1996 Ram 2500 Laramie SLT
Trim Level: Laramie SLT
Deereman39 is on a distinguished road
Question Towing
I am looking at a 1998 2500 V10 with 200,000 on it,and was wanting to know what kind of miles they are good for? I now have a 1996 2500 5.9 V8 and it will not handle my 16,000 LB 5th Wheel so will a V10 pull it ok?
Thanks Ed
Old 11-01-2013, 04:59 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
With that kind of weight, I would look at a diesel. Should be a big difference in fuel economy numbers while towing and an overall better experience, Also, depending on your tongue weight, you may want to consider a dually.
Old 11-01-2013, 06:20 PM
Deereman39's Avatar
Question towing
I would like to stay away from the diesel if possible.I drove the truck today and it is a 96 not a 98 but it seems to have plenty of power but I was told that you can not tow in overdrive with a dodge automatic,is this true?
Thanks Ed
Old 11-01-2013, 07:47 PM
Rep:326
I would not tow heavy loads in overdrive since OD is very weak. It's better to use a little more fuel towing in 3rd then to have to rebuild the transmission.
Since you don't want a diesel, you may also consider the 01-07 GM 2500 with the 8.1 big block engine. The transmission (Allison) will be much better than a 47re.
Old 11-07-2013, 09:53 AM
Sledpuller Sledpuller is offline
Vehicle: 1994 Dodge Ram
Trim Level: laramie
Sledpuller is on a distinguished road
I wouldn't be afraid of using the truck. My truck is a 5 speed, which I prefer for towing, but i have pulled both gooseneck and bumper trailers several times with no problems.
