Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-01-2013, 12:32 AM
Walt01Ram2500's Avatar
Walt01Ram2500 Walt01Ram2500 is offline
Vehicle: 2001 Dodge Ram 2500
Walt01Ram2500 is on a distinguished road
Question Gurgling sound from heater core and blower stuck on defrost
2001 Ram 2500 5.9L
This spring my radiator blew out and I had to have it replaced going through Canada. It was warm enough out then I didn't notice my heater not putting out normal heat but recently now that it's getting cold out and I'm using my heater I hear a gurgling sound coming from under the dash and the heater doesn't warm up the cab very well any more. I've looked around online and every other problem I've seem other people have with it gurgling is a leaking heater core but I don't have any fluid leaking onto the floor and I don't smell that sweet coolant smell. Any ideas?
Also in the last week my climate control selection to put it to either defrost or front vent or foot vent had been acting up and now is stuck on defrost.
Old 11-06-2013, 09:13 PM
LittleRed LittleRed is offline
Vehicle: 2001 1500 Dodge Ram
Color: red
Rep:24
LittleRed is on a distinguished road
I would definitely check your anti-freeze level. Maybe they didn't get all the air out of your system. I take the cap off the radiator when the trucks cold obviously don't take the cap off if its hot. Fill it with the truck running and wait until it gets to normal temp if its full the anti-freeze wont go down at the fill neck. I assume you can still turn your dial to floor ? or a/c etc? its just staying on defrost. Theres a vent door closest to your dial that controls where the heat goes. A vaccum motor controls that door. Just a thought that motor or Actuator could be bad and now it wont turn the door.
Old 12-19-2013, 03:48 PM
Hey thanks for the reply. I've burped the radiator and made sure it full on fluid now. Haven't heard a gurgle lately but still doesn't blow hot air. Blows kinda warm air but definitely should be blowing way hotter air. Im guessing the heater core is clogged and needs to be replaced. And I found a broken vacuum line that I fixed and now the the blower changes to all the settings like defrost, floor, face and what not.
Old 12-20-2013, 02:07 AM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
you could have the wrong thermostat in as well.
Old 12-20-2013, 10:33 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
My heater made that noise. I had a leaking head gasket because of an overheating. Would stop when I burped it, but would come back. The fluid was going into the oil, so no tailpipe smoke. Any milky stuff on the dipstick, oil cap?
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 12-20-2013, 11:35 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
Try having the heater core backflushed, shouldn't need replacing unless it leaks. Had a similar gurgling sound on another vehicle. Flushed the core, gurgle is gone and it throws way more heat.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 12-24-2013, 09:27 PM
Rep:194
Oh, forgot. One simple thing, check the radiator cap. Mine was bad and popped-off at 13 psi. This affected heat, and filled the reseviour. I also seemed to affect the ability of the rad to draw fluid back-in as the engine cooled after shut-off. Rented the AZ tester. New one tested to the factory 16 psi, and many issues solved.
Old 12-25-2013, 10:25 AM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
check the heater hoses coming out of the firewall. if 1 is hot and 1 is lukewarm you have a bubble or blockage. you can take off the colder 1 until coolant runs free and this will tell you if the core is blocked also.
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 12-26-2013, 10:06 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
All the 2nd gen Dodge Rams I've been in have made the gurgling noise when cold. My old one did and it would burn you out.
Old 12-26-2013, 10:24 PM
Rep:2664
all of the Dodge Rams climate controls had a few problems
check out the 3 youtube videos that were made by
HEATERTREATER Dodge
other videos about it
https://www.youtube.com/results?sear...dodge+ram&sm=1
2nd gen, climate control, heater core
