Old 11-01-2013, 03:58 PM
32seventeen 32seventeen is offline
Vehicle: 2009 Dodge Ram Laramie QC
Color: Brillant Black Pearl
Rep:25
32seventeen is on a distinguished road
Default Where to tap into the factory bed lights?
I want to hook up some under the bed rail LEDs and I would like to have them hooked up to the factory bed lights that are next to the third brake light.
Where is the best place to tap into that power?
Thanks
Old 11-01-2013, 04:09 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
There are lots and lots of threads on this topic. I think the "factory bed lights" that you're referring to is the cargo light (activated by a switch on the dash).
Here is a pretty good thread that gives some good info
http://www.ramforumz.com/showthread....&highlight=LED
I just did a quick search to find that one. A more complete search may give you better results, just be prepared to receive lots of "hits"
Can you also try PMing either Asur or SS4Luck. I think that they're some of the biggest LED guru's that we have on the Z.
Good luck
Exco
Bill
Old 11-01-2013, 08:30 PM
Asur Asur is offline
Vehicle: .
Rep:4364
Thanks
bring your wiring up under the rear seat on the passenger side, there is a hole there you can come up in, run the (+) wire into the cab and under the carpet to the area under the sill, there you can tap into the wire that goes up to the cab bed lights, if you pull off your cab 3rd brake light you will see the wire color that you need to tap into, find that wire under the sill and your done, I think on my truck it was the tan/purple wire, but not all trucks are the same, check yours and you will be good.
Old 11-01-2013, 08:35 PM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1464
^^ What Asur said. I did this exact same thing recently. I installed my bed lights under the rails and ran the wires exactly as described here. I wired them to where they illuminate with the cargo lights in the 3rd brake light assembly when I hit unlock on my key fob. If I need them on longer than the 30 seconds or so, I simply hit unlock again. They also illuminate (again, with the cargo lights) when I engage the cargo light button on my dash in the cab. Perfect setup and it has proven to work exactly like I wanted and needed.
Good luck with your install! It's not all that difficult once you know which wire.
Old 11-04-2013, 01:09 PM
Rep:25
Okay, cool! Thanks guys. I will pull the pass side rear sill and start testing with my meter. What is the easiest way to locate the hole that you guys used, from under the truck? Does it have a rubber plug in the hole?
Kai, that is exactly how I wanted it to work, it seems like the perfect source of power. I keep my bed cover on almost all the time, so the existing bed light is fairly useless.
Old 11-04-2013, 02:00 PM
Vehicle: .
Rep:4364
look under the truck around the area under the rear seat, you can even pull up the carpet and you will see it, plastic type plug, pull it off, pass your wires, I put a rubber grommet in the hole and then used Black RTV silicon to make sure no moisture would get through. The best way to find your wire, pull the 2 screws off your 3rd brake light and check the wire color codes, you will find that wire under the sill. You only need that one wire, its a Positive, use your body ground for the other wire.
Old 11-04-2013, 02:15 PM
Rep:25
My Laramie has a factory sub-woffer under the pass side rear seat. I'm not sure how that will complicate things, as far as finding that hole.
I have not looked things over yet. I was just collecting some basic tip before I start this job. Which sounds like it will go quickly.
I understand how to find the wire color and wire the lights. I was mainly looking for the info on where was the best place to tap that power.
Which seems to be at the pass side rear sill. Thanks again.
Old 11-05-2013, 07:58 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
On my 2013 the wire you are looking for comes down the drivers side door seal. My wire color was white with brown stripe. Yours may be different.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
