Replacement HighBeam/LowBeam fittings? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 11-01-2013, 04:25 PM
dothedr3w dothedr3w is offline
Vehicle: 2013 Ram 1500 Sport
Trim Level: Crew Cab Short Box
dothedr3w is on a distinguished road
Default Replacement HighBeam/LowBeam fittings?
Hey guys, just tried to install a set of Philips Diamondvision (H11) and Osram Night Breaker Unlimited (HB3) and neither of them fit!
These are the bumb fittings the manual calls for:
Base Quad Headlamp
LowBeam: H11
HighBeam: 9005
Premium BiHalogen Projector Headlamp
LowBeam: HIR2
HighBeam: 9005
If I'm not mistaken 9005=HB3. It's possible I ordered the wrong LowBeam but that doesn't explain why the HighBeam doesn't fit either. Does anyone know the correct sizes I'll need to order? Does the sport have the
Premium BiHalogen Projector Headlamps?
btw I have a 2013 Ram 1500 Sport CrewCab Short Box.
thanks a bunch in advance fellas!
Old 11-01-2013, 10:37 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
You said you tried to install new bulbs in your lights.
What bulbs did you take out?
The bulbs have the numbers printed on them so you should be able to see what you have.
Are your sure you had the tabs lined up correctly? They only fit one way in the hole and 1 tab is bigger than the other 2.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-02-2013, 10:11 AM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
The sport should have the projectors. My understanding was HIR2 is a 9012 bulb, this is essentially a newer version of a 9006. At least for the low beams. Fogs would be the 9006. High beams I believe are the 9005. Someone can correct me if I'm wrong.
