Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
tonneaucovered.com
Old 11-01-2013, 06:24 PM
NamgisFinn NamgisFinn is offline
Vehicle: 2009 Dodge Ram
NamgisFinn is on a distinguished road
Default Broken Plastic E-brake handle (AGAIN)
I've got an 09 1500 and was wondering if anyone else has had a problem with breaking their plastic e-brake handle. I've broken mine twice, and was hoping someone had a better solution than just using more cheap plastic.
Old 11-01-2013, 06:30 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Are you having to really pull on it hard to release the e-brake? It should only take very light pressure to do so. Sounds like you need the cable adjusted/fixed.
Old 11-01-2013, 08:36 PM
I push the skinny pedal
Rep:3308
^^This. Very little pressure should be required to release the parking brake.
Kurtis
Old 11-09-2013, 03:12 AM
No. Just jump in and pull it. I put the brake on every time I stop. And pull it with a fairly quick tug same as every other truck I've owned or driven. Mechanic at dealer said it happens a lot on late models. Just assumed it was a bigger problem. I'm very far from a dealer on an island, so I can't just drop by. Just hoping someone else has an idea. I'm gonna fashion something low budget (ugly probably) just to sort it out for now.
Old 11-09-2013, 03:22 AM
Rep:2737
My '09 emergency brake release is so touchy, that i can release it with a light touch of my fingers
it has 97,000 miles on it
I set the E brake before i put the Ram into the Park position when on any grade, on flat land i set it after i put it into Park
Ram 1500 SLT Quad cab, 5.7 HEMI(R) , 3.55 differential, EGR bug deflector, Bushwacker fender flares, custom soft tonneau, Line_X, DEBO Step, Mag-Hytec
2016 Ram 3.0 diesel undergoing Mods G2 tonneau, Line-X, Weathertech mats, Mag-Hytec differential cover, , customized Nfab bars, CB radio, Autonet wi-fi router
