Help with rear diff/axle - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-10-2013, 05:42 PM
Merc225hp's Avatar
Merc225hp Merc225hp is offline
Vehicle: 96 1500 4wd
Merc225hp is on a distinguished road
Odd's are it's was just the front pinion bearing, the 9.25 have a good history of these bearings going out. And to change that bearing you don't have to pull the gear carrier it can be done right from the front. Yes the Track locks have a bad rep, in most cases they go south because of lack of the use of the right oil additive or the lack of it.
As you have the ord truck it has 4.10 gears from the factory.
As I am new here I don't know if the forum has the FSM for dl but it would help you in your work big time.
1996 ram 1500, 7" lift longarm, Built 5.9, Dana 60's swap.
Old 11-11-2013, 05:59 PM
Fosrer6565 Fosrer6565 is offline
Vehicle: 2014 Ram 1500 Expess 4x4
Color: Black (package)
Fosrer6565 is on a distinguished road
Update figured it out..
Old 11-11-2013, 08:22 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
You mind sharing what you figured out? Just in case someone else has the same issue and comes across this while searching?
Old 11-11-2013, 10:18 PM
Haha just that i needed the specialty tool to remove the whole trac-lock assembly, the tool which most already know is the OTC 6602 differential bearing preload wrench.
Also are there any manuals or complete breakdown of specs for the rear diff? My haynes manual has nothing in it. I need to know the tolerances for everything. (this is kind of a PITA haha)
Old 11-13-2013, 03:25 AM
Rep:326
Try this:
http://forum.mopar1973man.com/downlo...p?do=cat&id=19
Mopar1973man has good stuff
Old 11-15-2013, 07:44 PM
Well this project of mine is getting the best of me , removing the pinion gear is seemingly impossible right now. I have been hitting a 2x4 with a 4lb hammer as hard as i can for 30 minutes straight and it hasn't budged.....Ugh losing hope haha.
Old 11-16-2013, 05:18 PM
Update: Going to call around to some mechanic shops to see what they will charge to rebuild the rearend, since my truck is pretty much dissasembled im going to have to remove the whole rear axle assembly. Since i already have all the parts im hoping for $1000 or less and im not going to the dealer because they are completely out of there minds on pricing. Well ill keep everyone updated on how this plan goes haha.
Old 11-18-2013, 10:15 AM
Awesome was just quoted with a full rebuild for $375 (I have all the parts and am pulling the axle out of the truck). I still need to buy a new ring and pinion gear, i have been reading that some gears make noise as they are not as high quality as others. Which set should i get? Yukon, G2 etc....?
Old 11-18-2013, 05:52 PM
Rep:326
Yukon or G2 should work fine. I'm not sure what my gears were since I reused the aftermarket gears that were already in there. They did make noise and it sounded like a tire hum from the rear end that you could hear above 50 mph.
Old 11-19-2013, 09:49 AM
They still made noise after you had it rebuilt?
