Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 11-02-2013, 11:26 PM
BamaDryver53's Avatar
BamaDryver53 BamaDryver53 is offline
Vehicle: 2000 Dodge Ram 1500 Quad Cab
BamaDryver53 is on a distinguished road
Question Lower intermediate steering column issue
Hi, I recently obtained a 2000 Dodge Ram !500. Got it cheap and knew it had some minor mechanical issues, (alignment,brakes) but I also found out the power steering has a problem. Seems as if the "boot" has come loose and the steering fluid is leaking from there. Is there a way to "re-seat" the boot, or am I going to be purchasing a replacement lower column?
Old 11-06-2013, 01:50 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Honestly, I don't know. And I wouldn't even start to guess unless I could inspect the vehicle. With that being said, here is my take on "the leak" and "the boot". CV (constant velocity) shafts have "boots" around them to keep the grease that's packed in them from flying off. The boot contains the grease, however, the grease is just sitting there, it is not pressurized. In a power steering system, the power steering fluid is a contained in a high pressure system, so I would think that the boot is just a dust cover and does not provide any containment of the fluid. So, more than likely, you've got a leak in your system, it just happens to be in the area of the boot.
Old 11-06-2013, 03:33 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I agree...what color is the substance it is leaking?
