Old 09-15-2013, 05:00 PM
letsgo19 letsgo19 is offline
Vehicle: 1998 ram 2500
Trim Level: 2500
letsgo19 is on a distinguished road
Default ball joint replacement
the ball joint on paasenger side end of drag link is shot.Can I replace just the ball joint or do I need to replace the whole drag link.It looks like I could but want to be sure before I buy one.Thanks
Old 09-15-2013, 05:30 PM
Trim Level: 2500
heres a pic of it but it looks like the ball joint is part of the link?
Old 09-18-2013, 03:25 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
I did "just the ball joint" on a 2wd 12 valve drivers side. R...
Old 09-18-2013, 04:00 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Gotta buy the whole thing. It's about $60 at Autozone.
Old 09-23-2013, 06:58 PM
Trim Level: 2500
I can"t for the life of get the castle nut off the inner tie rod.Are the threads backwords?Any ideas to loosen it?Thanks
Old 10-05-2013, 10:11 PM
Deereman39's Avatar
Deereman39 Deereman39 is offline
Vehicle: 1996 Ram 2500 Laramie SLT
Trim Level: Laramie SLT
Deereman39 is on a distinguished road
Default Drag link
1/2" drive Air impact.I replced all on my 96.
Old 10-06-2013, 09:31 PM
Rep:326
PB Blaster and a breaker bar. Or impact.
Old 10-31-2013, 04:11 PM
Trim Level: 2500
do you have to have truck jacked up to loosen castle nut?
Old 11-02-2013, 01:35 AM
jabba974 jabba974 is offline
Vehicle: 1997 Dodge Ram 2500
Color: Driftwood Satin Metallic
jabba974 is on a distinguished road
If you dont have an impact, try adding grease to the tie rod....if that doesnt help, heat the castle nut and drive a pickle fork in between the tierod and then try and brake the nut loose...It needs some pressure to keep the stud from turning
