Old 12-20-2013, 03:46 AM
Bigred74's Avatar
Bigred74 Bigred74 is offline
Vehicle: 1999 Dodge Ram 1500
Rep:258
Bigred74 is a jewel in the roughBigred74 is a jewel in the roughBigred74 is a jewel in the rough
hmm im tryin to understand that... lol and did you get any pics taken? as for the rear speakers.. the 6x9's are kickers and the stock rear speakers are still stock but if i were to hook them up id replace them with aftermarket speakers
il try to get some pics of mine too so we can see each others setups
*Bedliner paint job, leveling kit, 3'' body lift, 17'' eagle alloy rims series 197, 315/70/17 Nitto Trail Grappler M/T tires, S&B cold air intake, 52mm ported and bored throttle body, Superchips 3865 programmer
Old 12-20-2013, 03:24 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
If the rears will be aftermarket, then the should work fine hooked up to the deck. They might distort sooner and what not since the others are amped, but who knows.
and here how to take off those little hooks. But since my whole panel is off, this is what it looks like without it. Its got about an inch of wiggle room that I dont like.
But then basically, you take off the rear panels by:
-taking off the little piece by the door that overlaps the bottom of the panel.
-Remove the seat belt.
-then pop out that panel
And my bad. To get the rear panel out, only one side panel needs to come out, 2 will make it easier, but 1 is definitely needed.
Then heres the FIVE locations that the screws are in on the rear panel, forgive my editing on my phone haha
Heres a picture without the green lines . You might be able to see the actual holes, I think some might be covered by the green lines in the next picture. But there in that general location.
Front:
screw locations:
Then once you get that all out of your truck heres what the back should look like. Well, at least thats how mine looks!!
Then you just peel back the padding and theres 2 torx screws(not sure on the size) holding each hook on.
So basically just take those off, Then reverse everything to get everything back in!
Green Interior LEDs
Old 12-21-2013, 02:24 AM
Bigred74's Avatar
Rep:258
thanks!! but wow they really didnt want us to be able to take those out easily did they!
Old 12-21-2013, 10:28 PM
Rep:529
Apparently not!! They really should he just screwed in little brackets to the back that allow you to pop the clips on and off from the front.
Green Interior LEDs
Old 12-22-2013, 12:54 PM
Bigred74's Avatar
Rep:258
right!! you would have thought they would have just screwed them in from the front with like a small plastic cover that snaps in place to cover up the screw. i have heard some people say thats how it was done and then i looked at mine and i was like what the hell there is no covers on this what so ever!!
Old 12-22-2013, 05:35 PM
Rep:529
Ahaha not at all.
Green Interior LEDs
box, custom, led
