Old 11-03-2013, 12:48 PM
BradyC87 BradyC87 is offline
BradyC87 is on a distinguished road
Default Installing Wolo Bad Boy Horn
Has anyone put one of these on their truck and have any tips? I picked one up for my 2010 RAM 1500. I have the factory horns off but there is two separate horns and not sure what to do with the wiring. Assuming i will have to go pick up a couple connectors for it so i can just clip the wires onto the new horn and just throw a couple plugs on the two wires i wont be using.
Should be able to make the factory mounts work with just the one bolt and maybe a little reinforcing so the thing doesn't come loose and fall off.
Old 11-03-2013, 01:20 PM
Grubrunner's Avatar
Rep:3883
No idea what you're speaking of.
Post a link....
Grub out!
Old 11-03-2013, 04:08 PM
Asur Asur is offline
Vehicle: .
Rep:4364
This is what he is talking about
http://www.wolo-mfg.com/419-big2.jpg
http://www.wolo-mfg.com/air.htm
As for the wiring, I am presuming there are 2 wires going to the 2 horns, are you using the factory wiring to trigger a relay for the bad boys?
Old 11-03-2013, 05:28 PM
Grubrunner's Avatar
Rep:3883
Thanks, Asur.
Had NFC what he was talking about.
I got you soon....
Grub out!
