help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-03-2013, 10:20 PM
dmyers87 dmyers87 is offline
Vehicle: 1994 dodge b350 5.9l 2wd
dmyers87 is on a distinguished road
Default help
Ok, I got a 1994 dodge b350 maxivan with a 5.9l. My problem is that when I put it in gear and slowly push the accelerator it stalls, if I hammer on it, she will hesitate for a second but it'll go. There is a major voltagedrop when it's about it quit. So far I've changed the transmission thinking it might be causing it, no help. I've put a new battery, map sensor, throttle position sensor, idle air control valve, no help. I went and got another computer, at first it acted fine but withen 5 minutes it started doing it again. I've checked all my vacuum lines, and no leaks. I'm at wits end and need help of where to go from here.
Old 11-03-2013, 10:26 PM
Also, figured I'd add this. I've also replaced the cap, rotor, pick up coil, ignition coil, plugs & wires, intake pan and intake to head gaskets, and the fuel pump all within the past 6000 miles as well.
