Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 11-04-2013, 09:41 AM
KYSEAN's Avatar
KYSEAN KYSEAN is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express Crew Cab
Rep:21
KYSEAN is on a distinguished road
First question, did you break in you truck before towing with it?
When pulling that much weight that's just where your RPM is going to be on a gas engine because that's where the power is. That's pretty normal. A 2500 wouldn't be much different in that sense unless you went to a Cummins.
Good way to ruin an engine by towing that heavy without a couple thousand miles on it first.
Trailer Hitch, Line-X Spray In bed liner, S&B CAI, Magnaflow 22" and Y-Pipe, ARE Hard Tonneau Cover
Old 11-04-2013, 10:15 AM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
Originally Posted by drcleo55 View Post
Just purchased a 2103 1500 laramine with the 5.7 and 3.92 rear, rated to towed 9900 according to the dodge website and dealer. I plan on towing a 2011 jayco travel trailer that is 5300 lbs dry....probably 6300 with all our crap and I have the wife and two young kids to put in the truck. I had a Chevy Avalanche that was only rated to tow 7200 lbs and i was beating the crap out of the truck so along came the new ram. Towed this weekend for the first time with the ram and Im a bit surprised. Around town, it gets up and goes but I feel like on the highway its no better than the avalanche. Even in tow / haul mode the tranny shifts alot and actually stays in 4th most of the time at just under 3000 rpm and maybe 65mph. I felt like the hemi was screaming at me! Dont even ask about mpg!
Did i make a mistake? Should i have gone with a 2500 instead of a 1500?
I just dont want to beat the hell out of the new ride! Anyone know of some mods that might make towing a bit easier?
I don't think you made a mistake because then every other brand 1/4 ton truck out there must be a mistake as well. I towed 6500lbs every weekend with a 2006 Titan 4x4 CC and got barely 8 mpg but I expected that. Here's a big fact for gassers, they like being in the powerband when towing, which is where you were at, 2500-3500rpm. Don't compare a gas engine to a diesel, which likes to spend its time between 1800-2000rpm. Use your ERS and tow/haul and put your EVIC showing 4th gear. You will be fine brother. And engine break in before towing I believe is around 500 miles, as per owners manual.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 11-04-2013, 10:20 AM
drcleo55 drcleo55 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: larmi
Color: gray
Rep:26
drcleo55 is on a distinguished road
I have the 6 speed, 3.92 rear and the 5.7 l hemi....i was just concerned for long highway trips keeping the tranny in 4th at 2700 - 3000 rpm, 60 - 70 mph for a long time. Tranny temp never seems to go over 128 degrees. The old Avalanche tranny would get to close to 200 degrees! Sure the truck has plenty of power but am i beating the crap out of it? In 5th, any small incline and the truck seems to labor. I have a good weight distribution hitch and dont notice any trailer sway. I guess i should just keep the weight of the contents of the trailer to a minimum. Someone else suggested finding a big rig and drafting behind him (real safe!) but it does make an incredible difference. Good thing the powertrain warranty is 5years / 100,000 miles!! I just cant see buying a diesel 2500 for the 6 - 10 times a year i plan on towing.
Old 11-04-2013, 10:28 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
3,000 rpm with a hemi is nothing. I tow a 10,000 lb 32' fifth wheel Coachman with my hi miles 05. It tows way better than my friend's 01 2500 Cummins, seriously! If I want to haul azz, just step on the gas, very soon you are keeping up with traffic. Ok, it's revving up, but it has power! My friends old Cummins is like a locomotive, it builds up speed very slowly. His Cummins gets only slightly better economy towing. If I want to pass a slower vehicle when I'm towing with the hemi, step on the gas and you're gone. I have 3:92 gears.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-04-2013, 10:58 AM
SFVDOC's Avatar
SFVDOC SFVDOC is offline
Vehicle: 2012 Ram 1500 CC 4X4
Rep:83
SFVDOC will become famous soon enough
Keeping the Hemi "on the pipe" while towing is not going to hurt it. But yes it will suck the gas while doing so.
Old 11-04-2013, 11:22 AM
Trim Level: larmi
Color: gray
Rep:26
and yes.....i did break in the engine....owners manual said 300 miles of no hard accelerating and no break in period for the tranny....i waited till i got to 1000 miles before i towed
would a tune help? prob not
Old 11-04-2013, 12:05 PM
venom108 venom108 is offline
Vehicle: 2013 Ram 1500 express
venom108 is on a distinguished road
Some engines just like to be reved. 3000rpm really isn't a whole lot. The peak hp on these trucks is around 4500rpm. Considering you're pulling something that weighs as much as the truck you should feel it(try pulling your weight in a wheel barrel and see what happens). Diesels are great for towing but you have to add the cost of purchase, extra cost of diesel, and maintenance. Plus the fuel gelling up during the winter if you accidentally get crappy diesel. As long as your tranny temps stay low it's really not a factor how much it shifts.
Old 11-04-2013, 12:09 PM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:65
gusman will become famous soon enough
I honestly think my titan towed better than the ram (05 KC Big Tow).. did you get this impression as well? And ya 8mpg both trucks as expected haha
Old 11-04-2013, 12:31 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:778
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
Doesn't a Titan have more power than an '05 Hemi? If so that would make sense.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 11-04-2013, 04:01 PM
2010x3.92 2010x3.92 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:49
2010x3.92 is on a distinguished road
I occasionally tow my 67 Plymouth on our car trailer. The car weighs about 3700 and trailer around 2200 (older steel deck double frame rail car hauler). My truck has the 2010 version 5 speed transmission and with the car behind it the truck will roll right down the highway in overdrive right around 2000 rpms at 70. It will down shift if it needs to go up a hill but it doesn't act like the old 360 trucks that will downshift and go WOT max rpm.
I tow my boat quite frequently on the highway run to the lake. Mostly flat with rolling grades on the highway. The boat weighs 2400 dry and trailer 800. Add in gear and fuel and such and it tows it with no fanfare whatsoever. OD on the highway with no downshifts and last trip averaged right at 14.2 mpg (evic).
The peak HP on the current Hemi is way higher than the 4500 rpm stated above. Peak HP comes at 5600 I believe with peak torque at 3800. HP doesn't matter in maintaining speed. You ideally want the engine to run at or close to the peak torque output. That number will do the most work for a heavy hauler. That all being said, your hemi wouldn't think about breaking a sweat if it decided it needed to stay at 3000 rpm to maintain speed.
Is it very hilly where you tow? If it isn't even getting the trans temp past 130 degrees you haven't even scratched the surface or working the rig.
