bed suggestions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-04-2013, 12:20 PM
drcleo55 drcleo55 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: larmi
Color: gray
Rep:26
drcleo55 is on a distinguished road
Default bed suggestions
do most guys have a spray in bed liner or a bed rug / plastic insert?
how about some suggestions for a good bed cover
thanks!
Old 11-04-2013, 12:24 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:800
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
I'm not a fan of bed covers, but I think everyone should have a spray in liner.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 11-04-2013, 12:28 PM
spoiler's Avatar
spoiler spoiler is offline
Rep:372
I've got a factory spayed line-ex? or some such brand. It is high quality and I'm happy with it.
I've really been looking at a bed-rug lately. I use my truck for all things but loading it with rocks/dirt and gravel is pretty rare.
The bed rug is in my future (i think) but if anyone has one and hates it please speak your mind.
Old 11-04-2013, 12:35 PM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:42
theGSE10 is on a distinguished road
It kinda depends on what you plan to do with the bed....with that said:
If you're going to put a good tonneau cover or cab style cover on it then you can go with a bed rug or most DIY bed liners for light duty stuff.
If you plan on using your bed for more or have it open to the elements I would go spray-on like Line-x before a hard plastic one. The plastic ones tend to scrape the bed and will cause it to rust over time.
I work for a general contractor so I have to use my bed a decent amount. I went with Line-X and so far have had no complaints at all! Stuff can handle anything and comes with a pretty good warranty.
Hellwig SB, Green filter, Borla XR-1, Line-X, BakRollX, JBA TCC Shortys, Raptor 4" nerf, Hunter Bull Bar, Rigid LEDs, Moroso CC, Bilsteins @ 2.8, Fox 2.0 rear, TGC 1.75 spacer, Air Lift 1000, BakBox 2, DS Trinity, LMI mid-tube, 87mm TB
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
Old 11-04-2013, 01:19 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Spray in bedliner is the way to go for sure. Plastic drop in liners will hold water and random junk like rocks which will scratch away at the paint and start causing rust to form. Under my drop in cover, it looks like a war had happened
IG:@briley59
Old 11-04-2013, 01:54 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1056
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
I agree with the spray in liner guys once I got one on my current truck I decided I would never go back they are so nice
Old 11-04-2013, 02:04 PM
tlvzee tlvzee is offline
Vehicle: 2002 Dodge Ram 1500
tlvzee is on a distinguished road
I had a Line-X spray in liner installed when I bought my truck new in 2002 and its still going strong today. I've used it to haul dirt, crushed rock, construction materials, and tools. It's been a real good investment and has help up very well over the years.
I have also had a Pacesetter Jack Rabbit roll up bed cover for almost as long. I've been mostly pleased with it, but I recently found one similar to it called RETRAX, that looks like it would better seal out the water that leaks into the bed. It also has sealed roller bearings to make it glide open and shut easily. My Jack Rabbit's seals have worn over time and does leak a little.
I kind of liked the idea of the versatility of a roll up cover, knowing it most likely wouldn't keep out all the water like a rigid tonneau cover.
Old 11-04-2013, 04:20 PM
deekum1627 deekum1627 is offline
Vehicle: 2012 Ram 1500 Crew Cab 4x2
deekum1627 is on a distinguished road
mine came with the plastic drop in and i wanna get a line x much better protection and non slick surface. i have a bakflip cover and love it they just came out with the vp model looks awesome check them out
Flowmaster 40 series muffler with reso delete and Flowmaster tips/ bakflip cover/ AMP bed extender/ 3.92 gears/ 8k hids/ BT catch can/ S&B cai/ vleds fogs/ paramount bumper grille
Old 11-04-2013, 04:22 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
def do the spray in. Got mine done a few weeks after getting the truck, and i was very impressed. its also pretty thick. I think the liner i got sprayed in is around 1/16th of an inch if not more.
its an investment that will last the life of the truck, and well worth it.
Sponsored by:
Old 11-04-2013, 05:59 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
I'm afraid to remove my drop in liner because i'm scared to see whats underneath it..
Green Interior LEDs
