Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-04-2013, 12:24 PM
dodgeman118 dodgeman118 is offline
Vehicle: 1998 dodge ram 1500
Color: red
dodgeman118 is on a distinguished road
Default 98 dodge ram no heat and fluctuating temp gauge
i have a 98 dodge ram my temp gauge is fluctuating up to 230 down to about 205 i also noticed when the gauge gos up if i hit the gas it would go down almost instantly also the heat will stay hot on low for about 10 mins but on high it will go cold. to get the heat to go hot again i would have to turn the heat off and on again.
Old 11-06-2013, 08:46 PM
LittleRed LittleRed is offline
Vehicle: 2001 1500 Dodge Ram
Color: red
Rep:24
LittleRed is on a distinguished road
Your engine temp problem could possibly be your water pump. the fins may be gone so at idle or low rpms the pump isn't cycling much anti freeze then your temp goes down when you get on the gas cause the pump is doing something. As for your heater problem its probably this http://www.heatertreater.net/magento...php/dodge.html.
Old 12-13-2013, 06:45 AM
joshgly joshgly is offline
Vehicle: 1997 ram 2500 4x4 long bed ext
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
joshgly is on a distinguished road
I was having problems keeping my truck at temp, replaced the ignition switch for a separate reason and truvk now holds temp. Im thinking it had my fan running more than neccesary
heater problem, temp gauge problems
