Blower not blowing - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Place your Ad Here!
Old 11-04-2013, 09:16 PM
sonnymurray sonnymurray is offline
Vehicle: 2005 dodge ram 3500
sonnymurray is on a distinguished road
Default Blower not blowing
Here while back, then blower would start coming on when the truck was turned off. Then it started not coming on, then I noticed when I lowered the steering wheel it came on. Now, it won't come on at all. I checked the fuse, and it's fine. So that's not it. Any ideas?
Old 11-04-2013, 10:13 PM
dalboa dalboa is offline
Vehicle: 2003 Ram 1500 4x4
Rep:20
dalboa is on a distinguished road
Pull the connector at the blower motor and check voltage when operating switch on and off to see if it's getting power.
Was the switch in the off position when you discovered it running with the ignition off?
If it aint broke, find out why!
Old 11-04-2013, 10:34 PM
No, the switch was in the on position. I forgot to add that it is a 2005 3500 diesel.
Old 11-04-2013, 10:48 PM
Rep:2929
the Dodge Climate Controls have always had issues like yours
you can watch trouble shooting videos about it
go online to Youtube & type in Heatertreater Dodge
they have 3 videos just for the Dodge Vehicles & you will also see that there are many other videos on the same subject
Old 11-04-2013, 11:34 PM
Rep:20
Yeah, i also have a 06 3500 dually w 5.9 cummins. My horn quit working about the same time the actuator door in the heater box fouled out on me. GTYankee s got it right with the heater treater vids. They're pretty informative.
Your problem however sounds more like a wiring issue from your description. Not sure what would allow your blower to come on even with the ignition off unless someone has rerouted the power or changed the factory wiring. Are you the original buyer of the truck? Does the truck have any power accessories that have been added that one might have rerouted power to?
