Please help i cannot get this line off! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-06-2013, 09:18 PM
Truckinguy44 Truckinguy44 is offline
Vehicle: 1997 Dodge Ram 1500 Quad Cab
Truckinguy44 is on a distinguished road
Default Please help i cannot get this line off!
does anyone know how to remove the fuel line that comes from the tank to the line that goes to the fuel rail? it has a quick connect fitting with two grey tabs that i have never seen before. thanks so much!!!
Old 11-06-2013, 11:57 PM
dalboa dalboa is offline
Vehicle: 2003 Ram 1500 4x4
Rep:20
dalboa is on a distinguished road
I just removed mine after much effort. There is a safety tab that pops off both sides of the lines. I'm guessing that is what you're calling the two gray tabs. Anyway, that just lifts off the line. Then slide a metal (if possible) 3/8 fuel disconnect tool up into the top line and pull it off. I tried plastic at first and had no luck. The metal one popped it right off.
If it aint broke, find out why!
Old 11-07-2013, 12:00 AM
Rep:20
Are the tabs metal or plastic? If they are plastic you probably have to slide them down the line and hold while pulling the top line off.
Old 11-07-2013, 08:05 PM
the tabs are plastic. they are at the end of the line that connects to the line that goes up to the top of the motor
Old 11-08-2013, 04:54 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
In a jam, you can make one from a piece of a soup can, wrap around the line, and push into the fitting, to release the tabs.
