Old 11-13-2013, 10:09 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
Damn, the is a hearty trailer to pull with a 1/2 ton, but really it all depends on what you are putting on the trailer as to whether it will be to much or not. Im assuming lawn mowers, a bobcat and landscaping blocks?
Old 11-13-2013, 10:28 AM
5.2firefighter's Avatar
5.2firefighter 5.2firefighter is offline
Vehicle: 1999 Dodge Ram
Trim Level: Laramie SLT
Color: White/Grey
5.2firefighter is on a distinguished road
Bobcat mainly, and once in a while my uncles forklift. Now correct me if im wrong, but i can beef up the leaf springs to lets say 1 tons right? I have been looking at some diesels, i just cant afford them and gases are a lot cheaper to mod and run and work on.
Still looking for the right one!
Old 11-13-2013, 10:32 AM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Yes you can beef up the springs put the actual worry comes in with the tranny, diff and brakes. how big of bobcat are you talking, i dont think you should have to much of an issue unless it is like a t-500 or bigger then you are pushing the limits more and more
Old 11-13-2013, 10:40 AM
Color: White/Grey
It would be an s-510 i think its the smallest model bobcat
Old 11-13-2013, 10:49 AM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
i believe those trucks are rated to tow 7100lbs, someone correct me if im wrong, and the bobcat weighs 6200 so you will be close if not over to the limit after the trailer if you dont have anything else on the trailer or truck
Old 11-13-2013, 11:48 AM
Color: White/Grey
Now lets say i find a 2500 with the 5.9 v8, that would be a big difference in suspension and would easily pull a gooseneck.
Old 11-13-2013, 11:56 AM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
If you plan to do a lot of towing with that big of a goose neck and bobcat you would be money ahead to look at a 2500 IMO, but if you are only going to have to pull it every now and then i would say 1500 should be fine
Old 11-13-2013, 12:01 PM
Color: White/Grey
A 2500 without a cummins would be fine, what do you think?
Old 11-13-2013, 12:02 PM
Color: White/Grey
But with 1500s you can pull a good sized tandem axle car trailer, which is another option and would haul a bobcat no problem.
Old 11-13-2013, 12:10 PM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Im personally not a diesel fan they are way to much trouble for my, but that is my opinion. that being said a 1500 would do the job granted you beefed up the suspension, but the issue is if you get in a wreck while pulling a trailer that you are over weight for the truck you are asking to get into a lot of trouble, which is why IMO i would go 2500, both the 5.9 gas or diesel would do the job no problem
