Old 11-07-2013, 04:11 PM
LT Ram LT Ram is offline
Vehicle: 2014 Ram Crew Cab
Trim Level: ST 4X4
LT Ram is on a distinguished road
Default Aftermarket fender flares & Mud flaps
Recently purchased '14 Ram Crew cab, & having difficulty finding compatible fender flares & mud flaps. Some sites do not show '14, but I think it is identical to the '13 fenders. ??? Also, it appears that flares are not compatible with mud flaps that I have found.
In my interest to keep trim black like bumpers & grill,I would also like ideas about side body molding.
Has anyone used the ICI Rockerarmor? Comments? Thanks, Wayne (new member in NM)
Old 11-07-2013, 04:57 PM
blacklightus blacklightus is offline
Vehicle: 2014 RAM Limited
Trim Level: Limited
blacklightus is on a distinguished road
If you get flares, the body molded flaps will not work. Mopar does sell the flat flaps that would be compatible with the flares, but are not contoured.
As far as compatibility between 13' & 14' I saw no difference.
Old 11-07-2013, 06:16 PM
Rep:2642
2009 - 2014 Rams are basically the same body style, not counting the front body parts
the Electric steering changed the oil filter & the Catch Can positioning
molded flaps will not work with fender flares or flat mud flaps
newer Rams usually have two hooks for the driver side Floor Mats
Parkview Camera seems to be the same, but the wiring connectors at the Radio are different
Wiring for the door mirrors may be different, making upgrading to a better mirror is difficult at best
Brake controllers have been moved to the center console on the newer Rams
Old 11-07-2013, 07:21 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:83
Bushmaster will become famous soon enough
I emailed Huskyliner and they told me the mudflaps would fit with the factory fender flares but not the side steps. I didn't get the side steps. Will see if they fit when I get my truck on Monday(Nov 11).
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 11-07-2013, 11:12 PM
cb1's Avatar
cb1 cb1 is offline
Vehicle: 2014 Dodge Ram 1500 4X4
Trim Level: Sport Crew Cab 6'-4"
Color: Bright Silver Metalic
Rep:15
cb1 is on a distinguished road
I also have 2500 factory fender flares with no side steps and the Husky mud flaps seem to be the only option.?
I would like to know your opinion on fit, finish and how they look on the truck with the factory fender flares.
Can you please post pics once you have installed them?
Toyo AT2 Extreme 295/65R20, Bilstien 5100 Front Shocks Leveled @ 2.1", 2500 Factory Fender Flares, Husky Mud Flaps, Husky X-Act Fit Floor Liners (Front & Back), MBRP Pro Series Exhast, K&N Drop In Filter & Morimoto HID Lighting
Old 11-08-2013, 11:20 AM
RC51 RC51 is offline
Rep:58
RC51 will become famous soon enough
I was in aftermarket shop where my Weathertech molded mudflaps were in for my new truck that I have not received yet. They were ordered in for Ram with wheel flares like mine, however the box descriptor had 1500 for front or back mats (couldnt tell), and 2500-3500 for front or back mats (couldnt tell). He looked up the vendor number and they use the same descriptor code for my truck. We will see if it compatible..
Old 11-08-2013, 09:19 PM
Bushmaster's Avatar
Rep:83
Will post some before and after pics, probably getting my truck on tuesday(banks aren't open on monday) and have appointment to get my mods installed wednesday morning.
Old 11-08-2013, 09:30 PM
dad2steph dad2steph is offline
Trim Level: Longhorn
Color: White and Frost Gold
Rep:69
dad2steph will become famous soon enough
I just installed the Husky flaps on my 2014 Longhorn. I have factory flares and factory side steps. They fit perfect.
Old 11-08-2013, 10:51 PM
Catmaster's Avatar
Catmaster Catmaster is offline
Vehicle: 2014 Ram Crew Cab 149" WB
Trim Level: Laramie 4x4
Color: Monotone Black
Catmaster is on a distinguished road
I have Husky mud flaps on my Ram, they were bought for my 2011 Laramie with factory flares. They transfered to my 2014 with no issues. I had to buy some more 3M clear sticker for under them though (they come with 4 pre cut and contoured pieces).
They are by far the best fit and finish I could find, contoured perfectly and held on by the OEM lower two flare bolts. The rears come with one slef tapping screw each side for the inside of the flap to be secured - positioned through a pre drilled hole in the flap.
On my 2011 I had the wheel to wheel chrome running boards which were curved in at the ends a little, leaving plenty of clearance. However on my 2014 I have the stainless steel wheel to wheel boards which are straight and do contact the back side of the front flap.. Not enough to alter their function or look, just a small two inch long by 1/4 inch strip that I added some more 3M tape to slow the rubbing effect.
These flaps are a must have for anyone wanting to protect their paint. Sorry no pictures I can't seem to get them to load off of my crappy computer.
Old 11-08-2013, 11:35 PM
J Roc's Avatar
J Roc J Roc is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Rep:29
J Roc is on a distinguished road
I also only have good things to say about my Husky mud flaps, perfect fit and look good.
