Griott's 6 Inch Orbital - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Diesel Forums!
Dodge Caliber
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Place your Ad Here!
Old 11-08-2013, 10:35 AM
rrgmrg rrgmrg is offline
Vehicle: Shopping for a 2013 Ram 1500
Rep:104
rrgmrg will become famous soon enoughrrgmrg will become famous soon enough
Default Griott's 6 Inch Orbital
Going to order the 6 inch orbital. They also sell a companion 3 inch for tighter spaces. Anyone have both the 3 and 6 inch? Is it helpful or will the 6 inch be sufficient?
Old 11-08-2013, 11:06 AM
Ahays63's Avatar
Ahays63 Ahays63 is offline
Vehicle: 2014 Dodge Ram
Trim Level: sport
Rep:267
Ahays63 is a jewel in the roughAhays63 is a jewel in the roughAhays63 is a jewel in the rough
i have the porter cable and it uses 6" pads but theres not very many crevices i can think of that i would have used the 3" there was only a couple spots like under the mirrors where you could use it or maybe between the box and the cab in the grill it could be pretty hand i would imagine or the whole front end really
awww no mods yet due to restarting on a new pick up
Old 11-08-2013, 11:13 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
I have both and they are very good machines. The 3" will indeed get into spaces where the 6" is just too big and I find it is handy for scrubbing tasks with a yellow scrub pad. But for the few tight spaces involved, I am not sure it is worth the extra expense, as those areas can be done by hand. I use and like my 3" RO, because I have it, but if you are not wanting to spend the extra $$, you can get by without it.
Old 11-10-2013, 05:39 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
another cheaper alternative would be to order the 3" backing plate and 3 or 4 inch pads for your 6 inch machine.
Both are excellent machines though, and you can't beat the lifetime warranty on the Griots 6".
Old 11-11-2013, 10:39 AM
Rep:104
Great idea to order the 3 inch backing plate, thanks! I assume it's an easy swap?
Old 11-11-2013, 01:15 PM
Rep:912
yup very easy.
i mean don't get me wrong the 3" machine is quite a bit smaller, but the 6" has more power. personally i would try the cheaper route first and just order the smaller backing plate and see if that helps you get to the tight spots.
Old 11-11-2013, 05:24 PM
Vehicle: A Truck
Rep:2559
Originally Posted by primo spaghetti View Post
yup very easy.
This is a good solution, it may very well work for you. As Jeff said it is an easy swap and if you loose the wrench that comes with the RO, you can use a 9/16 or 14mm open end wrench.
Old 11-11-2013, 10:38 PM
Rep:104
Thanks you guys, going in with my nexst Griotts order!
