Bilsteins on the way!...question regarding them - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 11-08-2013, 03:41 PM
MLESa7990's Avatar
MLESa7990 MLESa7990 is offline
Vehicle: 2013 1500 Big Horn
MLESa7990 is on a distinguished road
Default Bilsteins on the way!...question regarding them
So I decided to order a set of bilstein 5100 adjustables for the front and bilstein 5100s for the rear.
...simple question, I guess...what should I set the fronts at? From what I have gathered, I am thinking 2.1...my truck is a little over 2 inches shorter in the front than the rear, so would this be correct to set to 2.1?...or will it settle and sit lower, making setting at 2.8 a better idea...I do not have plans of lifting the rear yet, but might consider a tgc 1 inch coil spacer in the future. Thanks, guys! getting these installed next Wednesday and can't wait!
Old 11-08-2013, 04:11 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
There may be a bit of settling. The difference on mine was 3 inches. I set mine at 2.8 and now I still have 1 inch of rake in the front. Go figure. Each individual truck will have variations. In your case it sounds like 2.1 is the ticket.
Old 11-08-2013, 04:43 PM
rb10475's Avatar
rb10475 rb10475 is offline
Vehicle: 2015 RAM 2500 PW
Trim Level: Power Wagon
Rep:50
rb10475 will become famous soon enough
I would go with 2.1. I just installed mine last week at 2.1 and it looks perfect. I originally had a 2.5" difference from the front to back. The truck still has a verrrrry slight rake (maybe about .125) but I was told by other members that if you set them at 2.8 it will look like your front end is higher than the back (a negative rake). Also at 2.1 the ride is better.
I can't stress this enough...get an alignment after you install them. I originally didn't think I did because my truck was driving perfectly straight. But, I listened to others on the form and once I got an alignment I was amazed at how much smoother the truck drove.
6.4 HEMI / Truxedo Lo Pro QT / Flowmaster Cat Back Exhaust w/ 50 Series Big Block Muffler / AMP Bed Step / DeeZee Tailgate Assist / AVS Aeroskin & Low Profile Window Deflectors / 3500 Series Tailgate Light / K&N Drop-in / UnderCover Swing Case
Old 11-08-2013, 04:57 PM
MLESa7990's Avatar
Thanks guys. Yea, it seems that folks that set them at 2.1 report less vibration issues than the ones setting at 2.8...and I already have my alignment scheduled for the day after install! I'll have to double check the height difference, but last I did, it was just over 2 inches....if I remember right it was 37'' in the front and just over 39'' for the rear.
Old 12-16-2013, 11:32 PM
BigRedRam1500's Avatar
BigRedRam1500 BigRedRam1500 is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Longhorn 4x4
Color: Deep Cherry Red & Gold
Rep:58
BigRedRam1500 will become famous soon enough
Those are about spot on from the measurements I took, 37' front and 39.5" rear... How bout some before and after pics !!!
