need to run on/off switch for backup camera - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Electrical
Old 11-09-2013, 05:20 PM
zero zero is offline
Vehicle: 2013 Ram 1500 Express
Rep:99
zero will become famous soon enough
Default need to run on/off switch for backup camera
Have a DCU topper (see thumbnail below) on my 2013 with the rearview mirror camera. Need the step by step install instructions for rewiring this to an on/off switch so I can have it on while driving if desired.
Old 11-10-2013, 12:34 AM
DarthRam's Avatar
DarthRam DarthRam is offline
BOOM! Collector
Vehicle: 2017 Ram 2500
Trim Level: Power Wagon
Color: Delmonico Red Pearl and Black Two Tone
Rep:1573
It can't be done without some type of aftermarket add on like NavTV, Crux etc. The camera has to be plugged in to a module and then in to the OEM display. The camera won't come in while in drive without one of the above.
• Cravenspeed Stubby Antenna • ICI Magnum RT Steps •ICI RT Red LED Step Lights • Dee Zee Tailgate Assist
Old 11-10-2013, 09:14 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Originally Posted by zero View Post
On my 2013 with the rearview mirror camera. Need the step by step install instructions for rewiring this to an on/off switch so I can have it on while driving if desired.
I reading this to mean that you've got a rear view camera that is hooked up to an aftermarket monitor that is in your rearview mirror. Is this correct?
If you've got the factory back up camera, then you're most likely out of luck, unless you pick up something like a Lock Pick, which are not cheap.
If you have an after market set up, you'll just need to install a switch inline with the trigger/ hot wire for both the camera and the monitor.
Exco
Bill
