tonneaucovered.com
Old 01-10-2016, 07:49 PM
eezridr eezridr is offline
Vehicle: 2015 Ram 2500 cummins 4X4
Trim Level: Longhorn
Color: olive / tan
eezridr is on a distinguished road
Default 35" on cummins 4X4 Mega cab
About to put a new set of tires on my 2500 mega cab 4X4 (Cummins).
The initial tires were 285 X 60 X 20. About 33.5" according to literature.
Was looking to replace them with Toyo Open Country AT II (295 X65 X 20) which is a 35" tire.
Curious if these will work on the front end without a leveling kit? If one is required, how much lift would I need?
EZ
Old 01-11-2016, 01:05 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
On a 2500, I think you've already got more than enough clearance for 35s.
Old 01-11-2016, 01:36 PM
Rep:2095
Yes 295/65/20's will fit on stock wheels without a leveling kit no problem. If anything, you may have a slight amount of rub on the sway bar at full lock but that would be it.
Old 01-11-2016, 04:24 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
6.4L HEMI Driver
Vehicle: 2014 Ram 2500 CC 6.4L HEMI
Rep:74
ShiftJockey will become famous soon enough
Yup...they will fit height wise.
Careful of going to full steering lock as it might rub. You can test this but do it at very low speed until you are sure.
Michael
2014 BIG HORN CREW
6.4L HEMI
Old 01-13-2016, 03:59 PM
h1seoul h1seoul is offline
Vehicle: 2016 Ram 2500
Color: Black Forest Green
h1seoul is on a distinguished road
if you added leveling, would that pretty much remove the possibility for rubbing?
Old 01-13-2016, 04:56 PM
6.4L HEMI Driver
Rep:74
Top to bottom rubbing won't be an issue.
Rubbing on the side might be at full steering lock due to the combination of stock wheel offset and the wider tire regardless of whether you level it or not.
You could use a spacer but what I'd do is try a test fit and see what happens.
Michael
2014 BIG HORN CREW
6.4L HEMI
