Can I stick my tube in this hole? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 11-09-2013, 11:51 PM
orlasTToy orlasTToy is offline
Vehicle: 2013 RAM 1500
Trim Level: 1500 Sport
Rep:70
orlasTToy will become famous soon enough
Default Can I stick my tube in this hole?
For draining my Bakflip tonneau cover!
I've seen some how-tos saying to drill thru spot #3 (in attached pic)
I'd hate to have to drill...can I route the hose thru hole #1? Will that drain water out of the bed?
Thanks all...
Old 11-10-2013, 12:41 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
#3 should knock out no drilling needed it should be rubber was on mine
Old 11-10-2013, 01:30 AM
Rep:70
thanks for replying.
any idea what the other 2 holes are?
i'd love to run the tube to #1...way less tube! dunno where it'd be emptying to tho...
Old 11-10-2013, 01:32 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
ya man no idea mine dont have those
Old 11-10-2013, 02:08 AM
1stRAM2012's Avatar
1stRAM2012 1stRAM2012 is offline
Vehicle: 2015 Ram 2500
Color: Black on Black on Black
Rep:123
1stRAM2012 will become famous soon enough1stRAM2012 will become famous soon enough
stick your garden hose in hole one see if it come out
MODS in profile
Old 11-10-2013, 02:22 AM
Rep:2968
squirt some water into it, I believe that you could even shove your fingers into the void from below the bottom of the bed
you could shine a light into the hole & have someone look from below the bed
Old 11-10-2013, 04:38 AM
nite ryder's Avatar
nite ryder nite ryder is offline
Vehicle: 2003 Dodge Ram
nite ryder is on a distinguished road
Hole #1 would empty the hose between the sheet metal of the bed. If you stuck enough hose into that hole it will come out below the bed and between the sheet metal sides of the bid. There is about a three inch space the two pieces of sheet metal that make up the bed.
"When you have a lot of things to do, it's best to get your nap out of the way first."
Old 11-10-2013, 05:28 AM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
I put removed the plug in hole 2 and put my hoses in there. Works fine and looks fine, I don't even notice them there anymore.
Old 11-10-2013, 11:48 AM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
The plug in hole 2 is plastic (at least mine was) so I just drilled through that. By drilling the right size hole the tube will fit better than just pulling the plug out and eliminate dust and water from getting in.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 11-11-2013, 05:47 PM
Rep:70
great, thanks all!
