Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 11-18-2013, 08:23 PM
ramcfl ramcfl is offline
Vehicle: 2013
Trim Level: sport
Color: gray
ramcfl is on a distinguished road
Plug 2, pull it out. The tube from the bakflip will fit right in the hole, no drilling required.
Old 11-18-2013, 09:04 PM
Asur Asur is offline
Vehicle: .
Rep:4371
I used hole number one, installed a 90 degree bend on my bed tonneau rails and ran a 24 in tube down to the bottom of the bed between the outside skin.
Old 11-18-2013, 09:31 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3238
PaulMys has disabled reputation
Hmm.... I suddenly have the urge to follow the wife upstairs.............. LOL!
Old 11-18-2013, 10:58 PM
orlasTToy orlasTToy is offline
Vehicle: 2013 Dodge Ram
Trim Level: 1500 Sport
Rep:70
orlasTToy will become famous soon enough
then be sure to use 1, 2, AND 3
Old 12-04-2013, 11:14 AM
windsurfdog windsurfdog is offline
Vehicle: 2014 Ram 1500 Pentastar
windsurfdog is on a distinguished road
Sorry for getting to this party late...
Just installed my Bakflip and cut about a 5" length of tube and installed using #1 on each side. It appears that #1 accesses the bed stake holder area plus a drain hole is in the bottom of the stake holder. I figured this would probably empty into the same area as #2 which I had originally intended to use. #1 was quite a bit easier with less tubing exposed. Also used a couple of tie wraps to secure the hose on the nipple.
BTW, I had to supplement some water intrusion around the tailgate with some small bits of the long strip of weatherstripping included plus I used a couple 6" lengths cut from the plastic bed liner type of material included to cover the stake bed access openings by the tailgate since the OEM bed rail liners on my truck have bed stake openings exposed in the rear. Has anyone else had any water intrusion with their Bakflip?
Thanks in advance for replies.
