Old 11-10-2013, 04:57 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2013 Ram 1500 Laramie
Rep:74
Nck will become famous soon enough
Default I'm completely lost now!!!
So here it is, for the last couple years my ride has had a satanic squeal whenever I would have the heat on in reverse or when I would turn or brake. So with someone inside turning the heat on and off, I noticed it would only squeal when the a/c compressor turned on. I've now completely replaced the a/c compressor, and it still does it, not as bad, but the thing is brand new! I don't understand this. Still only does it with the heat on, usually the defrost.
Old 11-10-2013, 11:10 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Did you happen to change the belt...Good Year Gatorback?
I'm guessing it's more of a mechanical squeal like a bicycle petal that has been neglected for far too long (is that an accurate description?), but I thought I'd mention the belt.
If not maybe this'll help...
I'd also check the alignment on the belt to the pulley. If the pulley is being angled-off center to the clutch it may cause some unwanted contact causing a squeal.
Old 11-14-2013, 06:20 AM
Nck's Avatar
Nck Nck is offline
Rep:74
Belt is in perfect shape, the belt is also aligned correctly from pulley to pulley.
And it for sure only squeals with the defrost on.
Old 11-17-2013, 11:13 PM
JwhiteH JwhiteH is offline
Vehicle: 2001 Ram 1500 Sport
Rep:15
JwhiteH is on a distinguished road
You replaced the compressor... Did you reuse the old pulley and clutch?
Old 11-18-2013, 07:40 AM
Nck's Avatar
Nck Nck is offline
Rep:74
No I didn't. Brand new compressor, pulley and clutch. Oiled and everything.
Old 11-22-2013, 07:40 PM
Vehicle: 95
Rep:1776
So...was I correct in assuming that it sounds like a mechanical squeal?
Squeak squeak squeak like an old bicycle pedal????????
Old 11-25-2013, 07:27 AM
Nck's Avatar
Nck Nck is offline
Rep:74
Yeah kind of, but it's a really fast squeak squeak squeak. It doesn't do it to much at all, at least not like it used to with the old compressor.
