Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 11-10-2013, 11:00 AM
james1114 james1114 is offline
Vehicle: 2015 Dodge Ram
Trim Level: Laramie 4x4
Rep:40
james1114 is on a distinguished road
Default Rust on Driveshaft
Hello
Newbie question, I don't know a lot about trucks, so I figured I'd try to learn by looking underneath and working my way up . I was looking under the truck and noticed some parts look rusted. I just got this 3 weeks ago.
I noticed it the most on driveshaft. Looks like water hits it and then rusts. But, it almost looks more like a patina finish. It's bright orange in color. Is this normal? A lot of humidity in FL....
Also, noticed a couple spots on axle where paint flaked off and it looks like surface rust (orange in color). Again, I'm trying to learn...forgive my ignorance.
On a positive note, I now know I have 3.21 axle thanks to this forum! ...learning.
Old 11-10-2013, 12:19 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:441
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
You are lucky to live in Florida, not Maine! We get road salt, brine spray, calcium chloride and anything else the state can put on the roads to eat your car. I just ordered an electronic rust prevention system from " Counter Act" in Vermont for my 2 2005 Dodges. Works a bit like a (Mercathode) system on a boat. Doubt if you need it unless you drive on the beach., but their phone# is 1=877-974-4700 . Never heard of a driveshaft or axle failing due to rust, but ask any Toyota owner in Maine how their truck's frame is doing.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 230,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-10-2013, 12:46 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Rep:616
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
You must have a 4x4, the 4x2s have larger diameter aluminum driveshafts. Its just surface rust, nothing to worry about. Some people paint theirs just because they don't care for the look, but I think most (including myself) just leave it. My truck has the same thing you're talking about, and my dad's 4x2 driveshaft is as clean and silvery as the day he bought it 4 years ago.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
Old 11-10-2013, 01:51 PM
Rep:40
Thunderhorse,
I have a 4x2. Part of the shaft is totally clean (end closer to engine), and the other part (closer to bed) looks like it may be aluminum; however, that's the end that has the rust on it.
Old 11-10-2013, 02:00 PM
Rep:616
Are you talking about the part where the shaft connects to the input pinion?
Old 11-10-2013, 02:18 PM
Rep:40
It's the shaft that connects to the rear axle. It has ridges in it (not smooth). The smoother, non rusted end, connects closer to engine.
Old 11-10-2013, 03:53 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
How about the rust forming on the rear axle. Don't forget that! Your axle might just break in half.... Remember, rust doesn't sleep.
Old 11-10-2013, 04:50 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:251
Ramzaq is a jewel in the roughRamzaq is a jewel in the roughRamzaq is a jewel in the rough
In about 100 years, if even then.
Old 11-10-2013, 09:38 PM
Rep:40
Ramzaq
Thanks for the insight and laugh. It doesn't seem to be damaging anything. Just hard not to notice it.
Old 11-10-2013, 10:33 PM
Rep:2705
the drive shaft may be aluminum, but the universal joints on each end are steel
a quick use of a wire brush & then use some POR 15 on them should stop the rust
the rear differential housing is a different matter
first of all, they don't get a full paint spraying at the factory, just like the underside of your Rams body, it is more of a fog spray
Then it is put on a cradle & travels on a moving track though the length of the assembly line, during that travel, the frame is mounted on it, then springs, brakes, steering, engine & transmission, etc. Then the body is dropped onto it & everything goes inside the body, then the doors go onto it. All of this time, the rear housing is still on the cradle & just before the end of the assembly line, the wheels & tires are installed & the vehicle rolls off of the track & out of the door. No one does anything about the marks that were caused by the cradle.
watch this video & you will see what i mean, it doesn't show the whole process & it is filmed sort of sporadically
