Old 11-10-2013, 05:46 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
Question 2 amps running on 8 gauge each?..
Right now i have my SPL z2x-1600 sub amp on 6 gauge power, and 4 gauge ground (I know they should be the same size but thats an upgrade for another time)
I'm adding a 4 channel amp. I have 2 distribution blocks that take it from one 4 gauge to four 8 gauge.
the 4 channel is only 50 watts per chanel. Am I good to run those amps with 8 gauge ground and power? I know I shouullddd be running at least 6. Heck, that 4 gauge ground barely fits on the SPL amp.
But will this worrkkkk until I upgrade all the wiring?
The SPL amp is running 740 watts RMS with three 25 amp fuses
The Alpine 4 channel will be running 200 watts RMS with 1 25 amp fuse.
Green Interior LEDs
Old 11-10-2013, 07:13 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
So run 4g from the battery to the dist block and them 8g to each amp?
The alpine will be fine on 8g power and ground, but that spl should really have 4g on both...
12 Flame Red RCSB Express- Sold 3/2015
17 Blue Streak R/T ordered 5/23/2017!
....the wait begins
Old 11-10-2013, 09:23 PM
Rep:529
more or less yes. however, the Power is 6 gauge.
Is this possible? My friend did this and it seemed to work for him. Two Sub amps, around a thousand watts each. and then a 4 channel amp
Take two of the outs for the power and ground, then run them both inter the terminal at the amp.
(this diagram obviously isn't drawn to scale....)
Green Interior LEDs
Old 11-18-2013, 01:46 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Wiring the way that diagram is set up won't accomplish anything better, unless you are worried about the wires downstream from the distribution block. The input for the distribution block will still only be a single 4 gauge wire (if I follow correctly).
Use this to help:
If you keep your runs short, you could use 8 gauge wire for your amps from the distribution block.
I ended up melting an 8 gauge wire that I was running a 500w rms amp off of while I was waiting for my 4 gauge wire to come in. But that was a long run, at least 12 feet.
Old 11-18-2013, 03:48 PM
Rep:529
^^ does that count the inline fuse in the 4 gauge? Or i think you just add them up right? haha
And the 8 gauge will be like 2 foot long maybe, for each section, so four 2 foot long 8 gauge wires.
edit:: and yeah, I know it will still be the 4 gauge in, Basically i just want to know if its safe to run the SPL amp off of the short 8 gauge. That way I don't have to buy different distribution blocks or any extra stuff.
Green Interior LEDs
Old 11-18-2013, 10:00 PM
Rep:326
You just don't count the fuse block and consider the wire to be 1 continuous wire run from battery to distribution block/amp.
Old 11-19-2013, 12:07 PM
Rep:529
so it looks like I should be good with running 8 gauge then? As long as the 8 gauge will be under 4 foot per each length.
Green Interior LEDs
Old 11-19-2013, 06:17 PM
Rep:326
Yes, you should be fine.
Old 11-20-2013, 01:14 AM
Rep:529
thanks!
15 characters
Green Interior LEDs
Rep:529
thanks!
15 characters
Green Interior LEDs
