Old 11-15-2013, 09:38 PM
Kiddanimal Kiddanimal is offline
Vehicle: 2006 Dodge Ram
Trim Level: SLY
Kiddanimal is on a distinguished road
Default Too much bass in my truck
I have a 2006 Big Horn with premium sound and there is too much bass. It sounds good but I have the bass setting as far down as I can go and the midrange is at about 1/2 on the negative scale, hi end is all the way up and still too much bass. Does anyone have any suggestions? I don't like the way people run their systems today with the trunk and doors vibrating from an over powered sub and this is a stock sound system. I am one of those folks that like to actually here the music. I do sometimes listen to classical and this system just won't do it for me. I am thinking that there is something wrong with it because the other trucks that I drove before I bought this one did not have this problem.
Old 11-16-2013, 12:47 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Possibly the fade is all the way to the rear? When you turn the bass all the way down, it usually cuts the bass completely out, that's weird. Also , is there possibly a preset EQ button on the head unit that has bass boost, rock, flat, classical setting? Maybe that is set on bass boost. Can't think of anything else it could be.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 11-16-2013, 01:50 PM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
maybe you should replace the 6x9's in your doors with something that does not produce the amount of bass a 6x9 does. A 6.5' speaker would do the trick.
Old 11-17-2013, 01:47 PM
Trim Level: SLY
I will check on the EQ preset idea. Speaker swap is something I have contemplated also. I might mess around with it some more before I go buying stuff.
Old 11-18-2013, 03:55 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
If you turn everything down and you still have bass then theres somethings wrong. I wouldn't buy speakers untill you figure out the problem. Aftermarket speakers will just end up the same. Even with 6.5s (not alot of bass) there would still be more bass than desired.
Green Interior LEDs
Old 11-18-2013, 06:31 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
My '06 was the same. I just turned the treble and midrange all the way up and the bass all the way down...
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 11-18-2013, 08:00 PM
Trim Level: SLY
Default I figured it out
The sound is back to what would be considered normal. I did have the fade pushed to the back apparently too much. All good now...
Old 11-19-2013, 12:09 PM
Rep:529
Woo! now you can throw in some nice speakers!
Green Interior LEDs
