Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Place your Ad Here!
Old 11-11-2013, 11:09 AM
Fosrer6565 Fosrer6565 is offline
Vehicle: 2014 Ram 1500 Expess 4x4
Color: Black (package)
Fosrer6565 is on a distinguished road
Default HVAC Problems
So I'm just trying to trouble shoot the problem and find out what i actually need to replace. Im thinking its the A/C Controller.
Anyways the first issue that came up was that the blower motor would never shut off, the speeds all worked fine but whenever i would turn the controller to off it would just slow the blower down a little bit more but would continue running. Other then that the vents would switch just fine and everything would work.
The 2nd issue that came up was now it won't switch between vents at all it only stays on the dash, different fan speeds still work, and it still wont shut off.
Any advice is much appreciated thanks!!
Old 11-20-2013, 09:00 PM
Okay, bought a new A/C controller. The only problem that im still having is that the blower motor will still not shut off completely. What was odd was when I had it completely disconnected i turned the truck on, the blower motor was completely off.
Help is much much appreciated thanks!
Old 11-28-2013, 09:14 AM
LittleRed LittleRed is offline
Vehicle: 2001 1500 Dodge Ram
Color: red
Rep:24
LittleRed is on a distinguished road
There is a resistor for the blower motor that sits inside next to the blower. Maybe its bad. I'm not sure I could totally be wrong, but might be worth checking out. I believe its pretty easy to get out.
Old 11-28-2013, 11:33 AM
thats my next route i ordered a new one just waiting for it in the mail now will update when i receive it.
Old 12-03-2013, 07:14 PM
ok so replaced the blower motor resistor and still same thing , the blower motor never shuts off. Any ideas ?
Old 12-06-2013, 03:07 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Bad ground or short in plug. Sounds like the plus is at least it works.
Old 12-06-2013, 09:26 PM
I'm wondering if it's between the blower motor resistor and the actual blower motor, I'm going to look at it again tomorrow. Maybe it will be an easy fix!
