Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 11-11-2013, 04:38 PM
MLESa7990's Avatar
MLESa7990 MLESa7990 is offline
Vehicle: 2013 1500 Big Horn
MLESa7990 is on a distinguished road
Default Body lift for a 2013
I wasn't quite sure where a body lift question should go...but anyways, I have a set of bilsteins going in that are being set to 2.1. I am also going to be adding a tgc 1 inch rear spacer to get a bit of rake back after the install depending on how it looks. I am tossing around the idea of adding a small body lift as well...specifically, the zone 1.5 inch body lift. What's everyone's thoughts on body lifts? I have never had one on any truck I have owned in the past...
Here is the zone bodylift I am considering
http://zoneoffroad.com/zone-offroad-...ram-1500/D9150
Old 11-14-2013, 10:14 PM
CWELCH CWELCH is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT Lonestar
CWELCH is on a distinguished road
Body lifts are a BADDDDDDDDDDD idea! Had a one a previous truck and dad had one on an old Blazer. My truck ended up snapping the body bolts connecting to the frame and body slid about a foot off the frame! Yikes! Go with a leveling kit instead, much cheaper and safer. Just need an alignment and all done! Will normally fit up to 35" tires and will provide the stance you are looking for. Hope this helps!
Old 11-14-2013, 10:15 PM
Do some digging around and you'll find all kinds of horror stories about them....plus you'll have a horrible gap between the body and frame
Old 11-15-2013, 07:08 PM
MLESa7990's Avatar
Thanks guys...already hav the truck leveled with the bilsteins, but i'll do some more snooping around on the forums for info...I've read mixed reviews...some folks say the body lifts are great, others not so much
