Old 12-06-2013, 10:41 PM
Rep:2657
almost all of the Dodge vehicles have near identical Climate Control units
some are just smaller then the truck units
on youtube, type in Heater Problems Dodge Ram 1500
HeaterTreater has 3 videos for trouble shooting Dodges
several others also have posted their own fixes
Old 12-08-2013, 09:17 PM
05cummins's Avatar
05cummins 05cummins is offline
Vehicle: 2005 Dodge Ram 2500 QC Cummins
05cummins is on a distinguished road
Originally Posted by lespr50 View Post
In another forum they talk about removing the blower an reaching in an pull the broken vent door. Another is Heatertreater.net (I think is correct) have a solution for the 3rd Gen Rams. Do a search on YuoTube you be able to find them.
I never really considered that being an option. It would def make getting through the winter a lot easier until I properly fix it in the spring lol.
Old 01-20-2014, 09:30 PM
Hallock21 Hallock21 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:30
Hallock21 is on a distinguished road
does the blend door control the opening and closing of the floor vents, i thought the blend door just controlled the temperature of the air coming in by opening and closing and letting outside air in?
Old 01-21-2014, 04:39 PM
05cummins's Avatar
No, thats not the blend door for the floor. thats the Mode 2 door, which controls floor and defrost.
I'm pretty sure your correct on the blend door, because then its the mode 1 door that controls between vent and floor/defrost.
Old 01-24-2014, 09:34 AM
Rep:30
Yes...05Cummins you are completely correct..the only issue im having is nothing coming out of the floor vents, if i select floor everything comes out the defrost. Hot/cold and all other functions work fine, just nothing out of the floor vents
Old 01-24-2014, 09:35 AM
Rep:30
so...off to youtube i go and searching Mode 2 door....thanks 05cummins
Old 01-24-2014, 09:52 AM
Rep:30
Of Course...the guy on heatertreater doesn't even recommend trying to fix/change the door because its such a pain the the as$...you have to drill spot welds, cut a support with a grinder and bend the metal housing back to access the motor...
Old 01-24-2014, 01:30 PM
05cummins's Avatar
HAHAHAHA i know right!! When I watched that video I was like, it cant be that bad...can it. YUP!!! It is. I tore apart 2/3 my dash in late novemeber early december. Got down to the dash support frame, but not far enough if I was going to that work I could yet. I moved the linkage around a bit for the mode 2 door and the motor, and I was able to obtain some heat on my side finally. passenger side always had floor heat (I didn't understand that one at all why one side does n one doesnt lol. prob cause i have dual climate) But I was able to get enough of an opening that i do get some heat now and it will warm my feet up eventually where before not at all.
I'm a smoker so i've started keeping it on just vents (and i need a new relay as well for my fan speed :'( ) so mine is always on high as well, so i just adjust the vents for where their pointing and how open they are, and i'm staying pretty warm.
Keep me posted on what you do and when ya do it. I'm going to change all my mode and blend doors in the spring when its soooooooooooo much warmer. then I'll be good for next winter. Summer won't phase me as much as I like my windows open with the music up loud lol.
Old 01-24-2014, 09:42 PM
Rep:30
I agree with this statement 100%....just looked and its 8 degrees outside right now, so i may just try to prop the door on the drivers side open a little, although he doesn't recommend that
Old 01-25-2014, 07:40 PM
05cummins's Avatar
Ya he doesn't...but it looked like he was changing his mode doors in pretty warm weather. He wasn't freezng his feet like we are or were. Godda do what we need to do right lol
