Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 11-11-2013, 09:22 PM
Kern Dog Kern Dog is offline
Vehicle: 2007 Ram 1500
Color: Inferno Red
Kern Dog is on a distinguished road
Default Serious "Brake-Shake" with a 2007 Ram
Since I found no forum dedicated to brake issues, I figured I'd try this one.
My 2007 reg cab shortbed SLT Ram 1500 has developed an annoying vibration that only occurs when the brakes are applied at speeds of 60 mph and faster. I had the tires balanced and rotated a few days ago and it made no difference. I replaced the rear brake rotors and pads with OEM Mopar parts, and the shake still persists. The front rotors and pads were replaced with Mopar parts a few months ago and all was fine then.
The tie rods are fine. The ball joints are fine. The upper and lower control arm bushings still look great. The truck has 174,000 miles on it.
My afternoon freeway commute often has unexpected slowdowns from 70+ mph down to a stop and this truck often shakes like I'm travelling down a cobblestone road.
How likely is it that the 3 month old front rotors could be warped? The truck stops fine under 50 mph, but I can feel some slight pulsating.
Old 11-11-2013, 10:00 PM
shawnu's Avatar
shawnu shawnu is online now
Vehicle: 2012 Ram
Rep:517
My 06 started doing this same exact thing...but then it was totaled so i never figured it out...
Wish i could be more help but im not..so a free bump for you!!
P s.- the brake shake did nit cause the wreck. Lol
12 Flame Red RCSB Express- Sold 3/2015
17 Blue Streak R/T ordered 5/23/2017!
....the wait begins
Old 11-12-2013, 01:13 AM
Color: Inferno Red
That is kooky!
I also had a 2006 that was totalled. It also had the same problem.
The 2006 I had was a 4x4. By 18,000 miles the brake shake started, mostly while slowing downhill. I had the dealer check the runout of the rotors. They were just a few thousandths out of spec. The rears were resurfaced and the problem was diminished but not eliminated. The front were resurfaced afterwards and while it seemed fine, the shake came back within 10,000 miles. The truck was totalled at 33,000 miles when I was broadsided by a guy that ran a stop sign.
Old 11-12-2013, 01:17 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
If it's not the rotors, then check the master cylinder, the combination valves and the anti-lock module. Could have a stuck caliper as well.
Old 11-12-2013, 11:57 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Sounds to me like the front rotors all right. I've seen many a new rotor go bad well before it's time. I'd have dodge change them because they should still easily be under warranty.
Old 11-12-2013, 12:23 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
I went through a similar thing about a decade ago, and it was the brake pads delaminating from the backing plates. Visually the pads looked fine, until you popped them out of the caliper and they fell away from the backing plate. Changed to a different manufacturer and the problem went away.
Old 11-12-2013, 06:27 PM
Nemmisis1 Nemmisis1 is offline
Vehicle: 2013 Ram 1500 sport
Color: BLACK
Rep:51
Nemmisis1 will become famous soon enough
Your front rotors are warped... That happens from heavy heavy breaking and heat.... Do your self a favor and look n eBay r1 rotor concepts...u need drilled/slotted rotors to get the heat off the pads quicker... Got a set on mine love them and they look great.!!!! All for less than 350 all 4 rotors and break pads... ...p.s get ceramic pads less dust...
Old 11-14-2013, 10:05 PM
Color: Inferno Red
It turned out to be the rotors....
I pulled them Tuesday night, had them turned yesterday, installed them last night. Todays drive showed ZERO shake.
The machinist said they weren't warped a whole lot, but they surely were not perfect.
All seems well now.
Thanks guys!
Old 11-15-2013, 01:27 AM
Rep:2968
Voonderbar! Thanks for the update.
