Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-12-2013, 01:14 AM
Sokar's Avatar
Sokar Sokar is offline
Vehicle: 1997 Dodge Ram 1500 4x4
Trim Level: SLT Laramie
Color: forrest green
Rep:26
Sokar is on a distinguished road
Default Another heater problem
From reading some posts on heater core problems, I think mine needs replacement, but I'm still not sure. I have the following problems:
1. truck has heat sometimes, but its Luke worm not hot (when it decides to turn on)
2. i smell antifreeze when heat is on, but no signs of leaks or drips.
3. The air comes out of the top vents only, even when I turn the controls to the floor.
4. Defrost setting fogs my windows
5. I hear a bubbling noise from the heater core, I "burped" the system a week ago and I am still hearing the noise.
I'm I correct about the heater core or is there any other ideas?
Any input will help
Thanks for your time!
1997 - Dodge Ram 1500 4x4
1991 - Chevy S10 Blazer 4x4
Old 11-12-2013, 01:50 AM
RogerRamJet's Avatar
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2939
Nope, sounds like you're right on the money. Time to start pulling out the dash.
Old 11-12-2013, 10:47 PM
Sokar's Avatar
Rep:26
Thank you for confirming
Old 12-13-2013, 06:41 AM
joshgly joshgly is offline
Vehicle: 1997 ram 2500 4x4 long bed ext
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
joshgly is on a distinguished road
Sounds like you may have a second issue aswell. If it only blows from the defrost you probably have a vacuum leak too.
Old 12-13-2013, 11:54 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
Before tearing it apart to pull out the core, go with a heater core flush. Just did one on the wife's car, made a world of difference. It also had been giving a gurgle when accelerating, I think it was when it started revving up that there was enough pressure to push through the heater core. After the flush, the heater blows nice warm air and haven't noticed the gurgle either.
I'm not sure when they went to electric blower doors to switch from floor to dash, yours may still be vacuum. If so, a vacuum leak may be the culprit for that problem.
Good Luck.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
