Old 11-12-2013, 06:16 PM
kimo13's Avatar
kimo13 kimo13 is offline
Vehicle: 2007 dodge ram
Trim Level: laramie
Color: inferno red
kimo13 is on a distinguished road
Default -44 offset rims??
im having a six inch lift put in come spring time and a new set of rims and tires as well. im just trying to get everything figured out now. the new xd rockstar 2 that I am thinking about buying is 22x12 and has a -44 offset. this is for the ram im not sure how this will look. I don't mind my tires poking out an inch or 2 but I don't want them so wide they're hitting oncoming traffic. could someone with a picture or at least a better understanding of offsets help me out here
Old 11-12-2013, 07:10 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
Jesus hell.. -44 offset.. Would your tire even be under your truck?.. I know with the level my 35/12.50 stick out 1-2 inches with my 17" xd addicts with -12 offset.
That being said.. If I could pull off -44 offset.. I would.. I love the fat stance look.
Tow mirrors up for the haters
Old 11-12-2013, 07:16 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
X2...wide stance lifted 4x4=smiles on my face!!
New audio build in progress
Old 11-12-2013, 07:20 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
You're probably not going to fit a 20x12 -44 offset wheel with only 6" of lift. You're going to need a 3" body lift on top of that if you want to clear a wheel that big. There are a few other threads on the forum of 3rd gen guys running 20x12's (forget what offset). Do a search for those and see exactly what their specs are. If I come across them again I'll post up the links here for you.
But yes, you're going to be sticking out a good 3-4" with those wheels and tires. If you want to only stick out 1-2" you need to look at 20x9 0 or -12 offset wheels.
EDIT: Here's the link http://www.ramforumz.com/showthread.php?t=152944
Old 11-12-2013, 07:26 PM
kimo13's Avatar
Trim Level: laramie
Color: inferno red
okay thanks and I definitely wouldn't try and fit a rim that big its just when I saw that the offset was that large I wanted to make sure on here. I know how offsets work I just didn't expect to encounter one like that. ill look around more because the -12 offset is the look I like I just haven't been able to find it on a rim I like yet
Old 11-12-2013, 07:33 PM
kimo13's Avatar
Trim Level: laramie
Color: inferno red
thanks for the link it helped out a lot. that doesn't look as bad as it sounded but yeah a little too much for me. I don't really like the idea of a body lift either I was trying to find an 8" suspension lift but that is quite the struggle with a half ton truck
Old 11-12-2013, 07:47 PM
Rep:2032
Doing an 8" suspension lift isn't overly hard on a 1500. Find a 6" lift kit, get Bilsteins for the front and set them at 2.1" and bam, 8" of lift. Then you'll just need a larger rear block for the back to make the truck sit properly. That's where you might have a bit of trouble.
Old 11-12-2013, 08:12 PM
kimo13's Avatar
Trim Level: laramie
Color: inferno red
this I hadn't thought of. im still trying to decide where I want my truck as far as lift, tire, and rim size. I was pretty set on 22 in rims with 35 or preferably 37" tires. as far as the ride height goes I just want to be able to fit the wheels I pick under the rig itself. I have until April to figure it all out but this was a big help thanks again
Old 11-12-2013, 09:25 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
6" or even an 8" lift on a 1500 is hard to get -44mm wheels to fit not impossible but most of the time will require a lot of trimming, a very popular size is 20x12 -24mm, 20x10 -24mm here are a couple quick picks of 20x10 -24mm
Old 11-13-2013, 08:41 AM
Trim Level: SXT 4x4
Rep:2802
How would I pull off 8" with rear leafs.. 6" + 2" bilstien in the front and what for the rear?
