Is there a speed limit for... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 11-12-2013, 10:50 PM
bsmith79 bsmith79 is offline
Color: Gray
bsmith79 is on a distinguished road
Cool Is there a speed limit for...
...the 2013 Ram 1500 while locked in 4-wheel drive? I thought I saw somewhere on the forum where someone just left theirs in 4-wheel drive lock all the time and frequently exceed speeds of 70 mph. There's nothing I saw in the manual about max speed in 4-wheel drive lock. Maybe someone can shed some light on this, yes?
Old 11-12-2013, 11:00 PM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
Whilst I can't say with certainty as I've not read through the book yet, I do believe it was 80km/h or 50-55 mph.
When I get the chance I will look it up in my booklet to confirm.
Old 11-12-2013, 11:14 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
There is nothing in the manual about maximum speed in 4 wheel lock. The only thing about speed is for 4 wheel low.
4WD LOCK
Four-Wheel Drive Lock Range - This range locks the front
and rear driveshafts together forcing the front and rear
wheels to rotate at the same speed. This range provides
additional traction for loose, slippery road surfaces only
4WD LOW
Four-Wheel Drive Low Range - This range provides low
speed four-wheel drive. It locks the front and rear
driveshafts together forcing the front and rear wheels to
rotate at the same speed. This range provides additional
traction and maximum pulling power for loose, slippery
road surfaces only. Do not exceed 25 mph (40 km/h).
Mods: Too many to list
Old 11-13-2013, 12:08 AM
macc08's Avatar
macc08 macc08 is offline
Rep:722
its not recommended to use 4wd lock on dry pavement. its more of a "sticky situation" thing.
Sponsored by:
Old 11-13-2013, 12:18 AM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
Last week, I found out I was driving around in 4-Lock for 2-3 days (as best I could remember). Earlier in the week, I put it in 4-Lock, for some icy/snowy back roads. I thought I put it back into auto (not realizing, you really need to hold the button for a few seconds).
In the end I didn't really worry about it too much.
Old 11-13-2013, 12:37 AM
darkstar darkstar is offline
Vehicle: 2013 4x4 express hemi
Trim Level: express
Rep:80
darkstar will become famous soon enough
it will go 80 in 4 low
trust me, but the comp wont let it go any faster
2013 express RCSB 4x4, 2.5in front, 1in rear lift, AFe stg 2 intake, magnaflow exhaust, Diablo tuned
Old 11-13-2013, 01:00 AM
reigirl's Avatar
reigirl reigirl is offline
Vehicle: 2013 Ram 1500 Outdoorsman
Color: Maximum Steel Metalic
Rep:23
reigirl is on a distinguished road
Do not worry about it; I took my 2013 outdoorsman down the track in 4high! Take of the anti-slip rear end and let her go. That 2013 differential is not the same as they use to be boys Ram has come a long way. That Hemi with nothing but a cold air intake will hit 100 mph in the quarter mile. But do not take my word for it. Just stop letting your truck drive you and have a little fun driving it.
but that is just my thought
I went to war for my country, and now you still have the right to tell me how wrong I was to do so.
Old 11-13-2013, 09:18 AM
Asur Asur is offline
Vehicle: .
Rep:4373
4 wheel drive High and 4 wheel drive Lock are two different things.
4 lock on the transfer case is to lock the output drive shafts together and eliminate the differential in the transfer case of full time 4WD systems. It doesn't have anything to do with the axle shafts locking together. You don't want to use it on high traction surfaces because of the potential for drive line bind that could result in damage to the transfer case, ie Dry paved Roads. Setting the case in the 4 lock locks the front and rear outputs together much like your air lockers.
For variable driving conditions, the 4WD AUTO mode
can be used. In this mode, the front axle is engaged, but
the vehicle’s power is sent to the rear wheels. Four-wheel
drive will be automatically engaged when the vehicle
senses a loss of traction. Because the front axle is engaged,
this mode will result in lower fuel economy than
the 2WD mode. When additional traction is required, the transfer case
4WD LOCK and 4WD LOW positions can be used to lock
the front and rear driveshafts together forcing the front
and rear wheels to rotate at the same speed. This is
accomplished by rotating the 4WD Control Switch to the
desired position. Refer to “Shifting Procedure” for specific
shifting instructions. The 4WD LOCK and 4WD
LOW positions are designed for loose, slippery road
surfaces only. Driving in the 4WD LOCK and 4WD LOW
positions on dry hard surfaced roads may cause increased
tire wear and damage to the driveline components.
Old 11-13-2013, 09:24 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Asur nailed it.
Old 11-13-2013, 09:40 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Ok so my question is If (hypothetically) I were to race some one at a stop light. (not that I would) and I put my truck in 4 Wheel High to get traction let her spool up and when the light turns green let her go can I drive her like that for traction purposes to not spin the tires ? and beat the hell out of the other car or truck.
And how fast can I go ? in 4 wheel high
(If I were to do that, again not that I would) but to avoid spinning the tires.
