tonneaucovered.com
Old 11-13-2013, 10:14 AM
trayne's Avatar
trayne trayne is offline
Vehicle: 2013 Ram Crew Cab 4x4
Rep:31
trayne is on a distinguished road
Do all the 2013 RAM trucks have the same 4x4 systems?
Flowmaster 50 series, K&N drop-in, Mopar chrome bed rails, Stainless step rails, DIY CAI, so far...
Old 11-13-2013, 10:23 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:446
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I race against Cummins Rams that run in 4WD Hi range. Thats the only way they can hook with street tires. In the eighth mile we're typically running at mid 70's mph, quarter mile, just under 100. As long as you're going in a straight line, 4WD is ok, if you turn, it can actually be dangerous. Sometimes driving in snow, my truck will kick the rear end sideways in 4WD. If you drag race in 4WD, you can possibly stretch the drive chain in the transfer case. I use my truck to skid out heavy logs in 4LO and have had to replace the chain. It's pretty easy to replace. I skid logs with 2-3,000 lbs in the bed and it will pull hard enough to break 15,000 lb dacron tow rope.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 235,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-13-2013, 12:49 PM
Rexer's Avatar
Rexer Rexer is offline
Vehicle: Ram 1500
Rep:207
Rexer has a spectacular aura aboutRexer has a spectacular aura aboutRexer has a spectacular aura about
Nope...mine doesn't even have AUTO mode...only lock and low
on a side note: anybody know the max speed that you can put it into 4WD LOCK?
Old 11-13-2013, 06:02 PM
darkstar darkstar is offline
Vehicle: 2013 4x4 express hemi
Trim Level: express
Rep:80
darkstar will become famous soon enough
like 3-4 mph iirc
2013 express RCSB 4x4, 2.5in front, 1in rear lift, AFe stg 2 intake, magnaflow exhaust, Diablo tuned
Old 11-13-2013, 06:03 PM
Trim Level: express
Rep:80
sorry, thats for 4wd low
Old 11-13-2013, 07:02 PM
RamJay's Avatar
RamJay RamJay is offline
Vehicle: 2013 RAM Outdoorsman
Color: white&mineral gray
RamJay is on a distinguished road
My 2013 Outdoorsman has only 2wd, 4hi,4lo,neutaral positions on the knob.I thought for the $$ it should have had 4wd auto as well.This is with the 6sp tranny and Hemi.
Old 11-13-2013, 08:07 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Originally Posted by Iqudayo View Post
Ok so my question is If (hypothetically) I were to race some one at a stop light. (not that I would) and I put my truck in 4 Wheel High to get traction let her spool up and when the light turns green let her go can I drive her like that for traction purposes to not spin the tires ? and beat the hell out of the other car or truck.
And how fast can I go ? in 4 wheel high
(If I were to do that, again not that I would) but to avoid spinning the tires.
Only Manual transfer cases have Four-Wheel drive High, other transfer cases have four-wheel drive Lock and four-wheel drive low, and others (higher end models) have four-wheel drive auto, four-wheel drive Lock and four-wheel drive low.
Four-Wheel Drive High Range - This range locks the
front and rear driveshafts together forcing the front and
rear wheels to rotate at the same speed. Additional
traction for loose, slippery road surfaces only.
If you have four-wheel drive Lock its essentially the same as four-wheel drive high, don't use it on dry pavement.
Old 11-13-2013, 08:22 PM
RamJay's Avatar
Any idea how the anti-spin diff. reacts when in 4wd?Would it just be over ridden?
Old 11-13-2013, 09:41 PM
Vehicle: .
Rep:4373
I don't think it will change much or react much different, Anti-spin is sort of like LSD, It has clutches inside the differential gears. If it "senses" a wheel slipping, it tries to push more torque to the opposite wheel. In 4wd Lock mod you will have both front and rear drive shafts locked in sync by the transfer case, so it would continue to work as an anti-spin diff and send power to whatever wheel has traction. In 4wd Auto mod I also think it will not change anything because the transfer case is only supplying power to the front wheels when needed as in loss of traction from the rear wheels, the Anti-spin will just keep trying to provide the wheel with traction with more power and if there is loss of traction then more power will be applied to the front wheels via the transfer case. Hope I explained that coherently.
