Old 11-12-2013, 11:37 PM
Raz6200 Raz6200 is offline
Vehicle: 2013 Dodge Ram Crew Cab
Trim Level: Outdoorsman
Color: True Blue
Rep:61
Raz6200 will become famous soon enough
Default Has this happened to anyone? How did you fix it?
So i was picking my son up from soccer practice tonight and shifted the 8 spd trans dial to drive and the beeping from the backup camera came on in a steady beep and would not turn off. Put the truck in park, nothing, turned it off and restarted and nothing, hit the alarm, nothing. I even looked in the uconnect settings to try and disable sounds, nothing. Turned off the park assist and still nothing. I had to drive all the way home with this constant beeeeeeeepppppppp! The only time it turns off is when I turn the truck off and open the door., but when I restart and put in drive the beep comes back. Has this happened to anyone else? If so what was the fix? I would appreciate any help, this is driving me crazy. Thanks
Old 11-13-2013, 12:04 AM
DWWHemiguy's Avatar
DWWHemiguy DWWHemiguy is offline
Vehicle: 2012 Ram
Trim Level: Express Quad Cab
Rep:37
DWWHemiguy is on a distinguished road
Maybe try disconnecting the battery? It should reset everything once you reconnect it. Could work.
Old 11-13-2013, 12:22 AM
Joeldude76's Avatar
Joeldude76 Joeldude76 is offline
Vehicle: 2009 Dodge Ram
Joeldude76 is on a distinguished road
I would say parking sensors but you said you turned yours off. I know that in the winter when I wash my truck sometimes ice freezes over the parking senors and makes the beep come on and stay on.
Old 11-13-2013, 01:00 AM
Color: True Blue
Rep:61
When you say parking sensors do you mean the camera or are these different?
Old 11-13-2013, 08:21 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
(1) I am sure you wiped off the parking sensors and pressed the button on the dash to disable the sound?
(2) Radio settings, turn off the Park Assist.
(3) Radio reset, press and hold the volume and tuning buttons at the same time.
(4) Pull off the positive battery cable for a computer reset 1/2 hour.
(5) Trip to the dealer for warranty repair.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-13-2013, 09:59 AM
Color: True Blue
Rep:61
1. Didn't wipe off the sensors(not sure where they are, is it the camera itself)? But I did turn off the parking sensors
2. Don't see this in radio settings, just a button on the dash under radio
3. This may be handy. Didn't know this one. Tks
4. Will try this if all else fails
5. Was going to be the next stop if it happened again today.
These are all helpful tips. Thanks
Old 11-18-2013, 11:13 PM
SupermanWV SupermanWV is offline
Vehicle: 2013 RAM 1500 4x4
Color: Copperhead Pearle
SupermanWV is on a distinguished road
Did you recently wash your truck at a self spray car wash or anything? When water gets in sensors then freezes a little. Then the sensors buzz non-stop. You can unhook sensors one at a time till buzz stops. Once it warms up and water gets out. The buzz will stop.
