Old 11-13-2013, 04:31 PM
macabra11's Avatar
macabra11 macabra11 is offline
Trim Level: Big Horn w/8 spd
Rep:23
macabra11 is on a distinguished road
Originally Posted by Rexer View Post
I have an 8 speed transmission and only have 4WD Lock and 4WD LOW
hmmm, maybe it's a hemi thing
Old 11-13-2013, 04:44 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:532
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
4wd auto comes on higher trim level trucks that have the Borg Warner 44-44 transfer case, otherwise you have the 44-45 transfer case. It is not that the 44-44 only comes with the 8 speed transmission or v8 with 8 speed or anything, its that the lower trim level trucks get the 44-45 transfer case and do not have the 8 speed as an option. I think the Lone Star (Bighorn) is the lowest trim line you can get the 44-44 case on, or maybe the SLT.
Before the 2013s, 4wd auto was available with the hemi/ 6 speed but only in the higher trim level trucks.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread).
Old 11-13-2013, 05:53 PM
rkuhl84's Avatar
rkuhl84 rkuhl84 is offline
Vehicle: 2013 Ram 1500 Sport QC
Rep:88
rkuhl84 will become famous soon enough
It does look like you could get the 4wd Auto function with the 2013 high trim level 6-speed's.
Old 11-13-2013, 07:18 PM
Breathing Borla's Avatar
Breathing Borla Breathing Borla is offline
Vehicle: 2013 Ram 1500 Sport 4x4
Color: Maximum Steel
Rep:89
Breathing Borla will become famous soon enough
never had an auto option but I am well versed in the others from owning a bunch of rigs
when is the deal with the auto 4wd in the Ram specifically?
all my toyota trucks just had 2wd, 4hi, 4 lo
I have a loaded sport hemi 8 speed so I do have an auto.
2013 Ram Sport Crew 4x4, 5.7, 8-speed, 3.92, LSD, Borla
2010 LTD Tundra DC, 4x4 RW Wheels 33" Cooper Maxx
2001 tundra, 2000 tundra
1995.5 Tacoma, 1997 Tacoma, 1998 Tacoma
Old 11-13-2013, 08:00 PM
nickb nickb is offline
Vehicle: 2013 Ram 1500 4x4
Rep:17
nickb is on a distinguished road
I have an auto selection on my 13 Ram 1500 Big Horn hemi 6speed tranny.
Old 11-13-2013, 08:26 PM
Rep:532
Exactly, it has nothing to do with the transmission, and everything to do with the trim line.
Old 11-13-2013, 09:45 PM
Asur Asur is offline
Vehicle: .
Rep:4371
4WD AUTO mode, the front axle is engaged, but
the vehicle’s power is sent to the rear wheels. Four-wheel
drive will be automatically engaged when the vehicle
senses a loss of traction. Because the front axle is engaged,
this mode will result in lower fuel economy than
the 2WD mode. When additional traction is required, the transfer case
4WD LOCK and 4WD LOW positions can be used to lock
the front and rear drive shafts together forcing the front
and rear wheels to rotate at the same speed. The 4WD LOCK and 4WD
LOW positions are designed for loose, slippery road
surfaces only. Driving in the 4WD LOCK and 4WD LOW
positions on dry hard surfaced roads may cause increased
tire wear and damage to the drive line components.
4wd Auto can be run on any surface at any speed.
Old 11-14-2013, 12:57 PM
Rep:89
perfect, thanks
Old 11-14-2013, 01:03 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
If it's anything like my explorer, 4x4 auto will make some very unfriendly sounding noises when it engages. I never got used to that noise.
Old 11-14-2013, 03:08 PM
Ruggasaurus88 Ruggasaurus88 is offline
Vehicle: 2013 Dodge Ram
Trim Level: Outdoorsman
Color: True Pearl Blue
Rep:40
Ruggasaurus88 is on a distinguished road
What's the difference from 4WD Lock and Lo?
