Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 11-16-2013, 02:02 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
Question Burning oil
2005 QCSB with 70000 on the odometer using about 1 quart every 5000 miles, is that anything out of the normal. I have no internal mods and it doesnt smell like oil in the exhaust. Any help is appreciated greatly.
Old 11-16-2013, 02:36 PM
Rep:2616
Have you done any tests ?
Compression dry & wet
Radiator pressure
are you running a catch can ?
have you ever used Sea Foam?
when was the last time that the spark plugs were changed?
Old 11-16-2013, 02:49 PM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Its a 3rd gen so I cannot use a catch can.. sadly, I changed the plugs at 65k. I put a can of seafoam in every 3 tanks of fuel regularly. My coolant I flushed 10k miles ago and the level hasnt moved and is still the same red color it was when I put it in. And I have not ran any compression tests.
Old 11-16-2013, 03:11 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:418
A quart every 5,000 miles? That's normal for any big V8 motor, I think. I've had Mazdas that burned a quart every 1,000 miles when new, quart every 500 miles with 100,000 miles. Try Penzoil Platinum 5W20 oil, you might be surprised after a couple changes. I used to use Mobil 1 in both of my hemis, switched to Platinum and Fram XG 16, now my 280,000 mile RT Magnum uses 1 qt every 15,000 miles. The oil that I remove after 15,000 miles looks amber not black. Check out this report.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-16-2013, 03:20 PM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Thank you sir. I figured it wasn't out of the extreme norm but it still bugs me I was running mobil 1and it was about 1 quart every 3k so I switched to amsoil and it was slowed to 1 quart every 5k
