Not happy with Magnaflow Y Pipes - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > Exhaust
Old 11-13-2013, 03:11 PM
HOTRODHARLEY's Avatar
HOTRODHARLEY HOTRODHARLEY is offline
Vehicle: 2013 Ram factory order
Color: BLACK
Rep:256
HOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the rough
Default Not happy with Magnaflow Y Pipes
I made up a quick cross section sketch of the Magnaflow #10778 Y pipe that we commonly use on our trucks. I've highlighted with a red arrow showing a lip on the outlet side that will clearly be a restriction and cause reversion. Now I'm not sure if this is a flaw in the one I have or is it the way they are all built.
If someone has one laying around. Stick your hand inside and feel for that lip. Let me know what you find.
Belltech 3"/5" Lowering kit. Belltech Rear Swaybar, Flowmaster Y Pipe, Custom 4" Single Exhaust w/ 4" Race Magnaflow, 22" SRT10 Wheels, Moroso Catch Can, Undercover SE Tonneau Cover, Weathertech Techliner Bedliner, Diablosport Trinity w/ Hemifever Tune
Old 11-13-2013, 06:45 PM
Grubrunner's Avatar
Rep:3883
Wow! I'm not the only one that's anal.....
I swear, I too felt that when I had mine. I think it's a tad more evident than what your sketch portrays.
It really didn't concern at all, but for sheet-n-giggles, I pointed it out to my exhaust guy. His reply?
"Are you serious? C'mon Ed.... take you skirt off! It won't be an issue and most certainly be much better than the crushed scrap-metal on there now"
I don't believe reversion will be an issue as far as flow, performance and/or sound is concerned. My exhaust guy shares my opinion.
Good observation indeed.
Grub out!
Old 11-13-2013, 06:57 PM
Rep:2929
this has 4 images of that Y pipe, move your cursor over the images to ZOOM in
http://www.etrailer.com/Accessories-...w/MF10778.html
Old 11-13-2013, 09:36 PM
Color: BLACK
Rep:256
I picked up both the Magnaflow #10778 Y Pipe as well as the Flowmaster #Y250300 Y Pipe. Let's just say the Flowmaster is a much nicer piece. It has very smooth edges and transitions inside. Where as the Magnaflow does not. Take a look at my pics.
Old 11-13-2013, 11:19 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
If I was ever going to it, it would be the Flowmaster hands down.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 11-13-2013, 11:35 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
That is actually not a restriction. It seems counterproductive at first, but it actually is better than a smooth transition. That lip will allow more air to be pushed through the pipe faster.
I certainly have been wrong before, but applying what I've learned, that is actually better than a smooth transition.
The velocity of the exhaust gas is theoretically zero immediately beside the tubing wall. The closer you get to the exact center of the tubing the faster the exhaust velocity. With that lip, you have more exhaust volume that is away from the wall of the tubing, which means more volume will enter the singles exhaust(in that y pipe). To optimize that design the lip would be "mushroomed".
Sean
Old 11-13-2013, 11:46 PM
Color: BLACK
Rep:256
I know it's not a restriction. I know all about transitions and anti reversion properties. When air flow is going over the lip. It's not so great when airflow is going straight into a sharp lip as is on the 3" exit of the Magnaflow Y pipe. I'm gonna have to cut this y pipe in half to get my point across. And for the measly $20 it cost I probably will.
Old 11-13-2013, 11:50 PM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport lowered 4X4
Rep:488
Send it to me,it'll save you the work of cutting it open,lol.
Old 11-13-2013, 11:54 PM
snrusnak's Avatar
Rep:1388
You don't understand. I know exactly what you are saying as I noticed it on mine when I got it. There is an approximately 1/8" to 1/4" lip sticking into the y pipe from the 3" exit. This is what I'm talking about. This is actually better than a smooth transition.
I know, like I said above it seems like it would be a restriction to the flow of the exhaust gases, but it's not. This concept is most often used with intake manifold design.
Here's a picture of an example of this being used in an intake manifold:
This will actually flow more than "smooth/flush" transitions.
You may know what a velocity stack is, it's similar theory. It would be best if the lip on the 3" exit of the y pipe was mushroomed, but still having the lip is not a bad thing, and I think it would actually be better than if it were smooth.
In reality though, it doesn't really matter. It probably makes a .00000001 hp difference either way lol.
Sean
Old 11-14-2013, 12:01 AM
Rep:488
I know, like I said above it seems like it would be a restriction to the flow of the exhaust gases, but it's not. This concept is most often used with intake manifold design.[/QUOTE]
Intake works under vacumn,not pressure like what's in a exhaust pipe.
Put a forced induction set-up on your intake,and smooth transitions will flow more then the step transistion
You don't build your header pipes to stick into the exhaust port.
You want smooth transitions under pressure,think stepped headers or collectors
