Old 11-14-2013, 06:50 PM
Klrpanda Klrpanda is offline
Vehicle: 2009 Dodge Ram
Klrpanda is on a distinguished road
Default Supercharged guys Spark plugs help
hey fellas what spark plugs are you running and what gap are you setting them at?
2009 RC Hemi-Edge 3000 Stall, AFE CAI,Diablo Tuner, CMR Tuned, 2011 R/T Axle 4:11 Gears, E-Fan
Old 11-15-2013, 08:19 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I don't have a blower but I spray nitrous (essentially the same) I run the same plug that is specd for a 6.1 SRT8 and I gap .35. 1 heat range colder copper if you can find em, NGK or Champion. Not sure Champion makes colder than our stock plug, however. You don't need platinum or Irridium, personally I think the copper plugs give the hottest spark. If I was running a lot of boost or spraying a 150 or bigger, I'd check out the Brisk plugs. Gapping closer than stock .35 prevents blowing the flame out and misfire. For example 300 hp boost would require .25 to prevent misfire or .30 depending on plug.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-15-2013, 10:05 PM
I push the skinny pedal
Rep:3277
I'm running the Denso 3381s gaped to .035 running 12psi and a 100 shot for track days. If I have any issues with spark blow out I'll be tightening the gap to .025. You need to pay attention to the type of taper and seat on the plugs, there is a difference between the Eagle and pre-Eagle heads. The pre-eagle heads have tapered seats and the Eagle heads need a flat seat. The Denso 3381s have a heat range of 6, the same as the NGK 2315 which are 2 stages colder.
Kurtis
