Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Place your Ad Here!
Old 11-15-2013, 01:07 PM
holderman19's Avatar
holderman19 holderman19 is offline
Vehicle: 2011 Ram 1500 Sport CC 4x4
Color: Deep Water Blue Pearl
holderman19 is on a distinguished road
Default oil change prep help
My Amsoil and filter are on the way, can you all help me out and let me know exactly what tools I need for the oil change. Socket size? Do i need a filter socket? Thanks.
Thanks, Ed
Old 11-15-2013, 01:38 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
just remember you a draining 7 qts...takes a large drain pan. Its pretty simple.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 11-15-2013, 02:48 PM
I have changed my own oil in my other vehicles before, just wondering what size socket i need and how hard it is to get the filter off by hand or if you need a special wrench/tool. I have not been under the Ram yet.
Thanks, Ed
Old 11-15-2013, 02:52 PM
audio1der audio1der is offline
Vehicle: 2012 Dodge Ram
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
I can't recall the exact socket size, but its a common one in most socket sets.
If this is your first change, I hope you have a filter wrench handy because they use Optimus Prime to screw the filters on at the factory. Even with my filter wrench I nearly needed a breaker bar to loosen it.
the large drain pan is not a joke, either. It's a lot of fluid to deal with.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 11-15-2013, 05:02 PM
Fliehigh's Avatar
Fliehigh Fliehigh is offline
Vehicle: 2015 Dodge Ram 1500 Laramie
Color: Granite Crystal Metalic
Fliehigh is on a distinguished road
I had to pierce the filter with a screw driver to get the filter off. Didn't have a wrench that would budge it.
Old 11-15-2013, 09:45 PM
Thumbs up
Wow. No this is not the first change for the Ram, just for me doing it myself. Got it with 24k miles 4 months ago. Dealer did other few changes. Thanks for the replies. I have a nice size drain tub, since i have the clearance guess i'll get a bigger one just to be safe and make it easier to move when full.
Thanks, Ed
Old 11-16-2013, 03:00 AM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport lowered 4X4
Rep:488
The factory puts the filters on when the motor and filter are cold.
Then when you warm the motor up to operating temps to do the first oil change,the gasket expands from the heat.
If you're doing the very first oil change on a new vechicle try cracking the filter loose first while the motors cold,then just barely re-snug it to warm the engine up.
It usually helps on that first ugly filter change
Old 11-16-2013, 10:00 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
I would recommend an oil filter wrench that fits to a socket wrench along with a socket wrench extension of at least 3", 6" I prefer.
Old 11-17-2013, 07:37 PM
Sounds good Hermes1. Thanks all. This is not the factory filter so it might not be crazy tight but the break it loose then snug and then warm up engine idea still sounds good.
Thanks, Ed
Old 11-19-2013, 02:49 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
usually a 13 mm socket for oil plug...look into the Amsoil bypass filters too and your oil change intervals could be once a year like mine...
amsoil, oil change
