Old 11-16-2013, 10:34 PM
Grubrunner's Avatar
Rep:3883
I have the Vararam Air Grabber and a Magnaflow muffler. So I am not going to see any difference from stock with a 87mm throttle body?
For $400.00 most probably not as things currently stand with your truck, however, you have a tool there that will supplement possible future improvements very nicely; that you paid $400.00 for.
For Arth's $250.00 most probably not as things currently stand with your truck, however, you have a tool there that will supplement possible future improvements very nicely; that you paid almost half the price for.
Jump on Arth's. It's a steal.
GL.
Grub out!
Old 11-19-2013, 04:05 PM
audio1der audio1der is offline
Vehicle: 2012 Dodge Ram
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
^ Agreed.
Read the sticky at the top about ported throttle bodies. It has a lot of useful opinions from people with nothing to gain from selling them (vendor hype)
IMO it took polishing, knife-edging and port-matching the ported TB to my intake to make any noticeable difference over (already had an S&B CAI) stock.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 11-19-2013, 08:58 PM
HOTRODHARLEY's Avatar
HOTRODHARLEY HOTRODHARLEY is offline
Vehicle: 2013 Ram factory order
Color: BLACK
Rep:256
HOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the rough
Originally Posted by audio1der View Post
^ Agreed.
Just did mine. Except the knife edge. And a "noticeable improvement" is a big stretch. Even with or without the knife edge.
Belltech 3"/5" Lowering kit. Belltech Rear Swaybar, Flowmaster Y Pipe, Custom 4" Single Exhaust w/ 4" Race Magnaflow, 22" SRT10 Wheels, Moroso Catch Can, Undercover SE Tonneau Cover, Weathertech Techliner Bedliner, Diablosport Trinity w/ Hemifever Tune
Old 11-20-2013, 01:34 AM
Rep:201
I did the knife edge, polish and port matching all at once so I don't know which part contributed to what, but before that(with the PTB), there was NO noticeable gain to throttle sensitivity, acceleration or anything. After the 3 mods to the PTB I could JUST tell it was there at WOT. No night and day differences, that's for sure. But it took doing those 3 mods to the already modded(ported) TB to tell any difference from stock.
Old 11-20-2013, 08:33 AM
Hornet Hornet is offline
Vehicle: 2013 RCSB Ram
Rep:470
The only way you're gonna stuff more air through a certain sized venturi hole is remove the restrictions that cause turbulance,that means knife edgeing and smoothing the bore out till it shines.
You can taper the bore before the hole till the birds come home,but it'll still only flow as much as stock till things are smoothed out internally.
Boundary layer principles don't apply in a venturi,it's not a port or piece of pipe.
Knife edging your stock throttle body will give you more then a ported throttle body that uses the square edged throttle blade yet.
The blade bounces air and causes turbulance
