S & B or LMI - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 11-18-2013, 11:42 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Originally Posted by macc08 View Post
did you order through bully's? if so, how much total?
For the entire intake through us is $264 delivered, if you find a lower price we will match it or beat it. http://bullysperformance.com/dodge-r...nufacturer=101.
The SRI's almost always give more horse power, as it is not just how cool the air is, however the air velocity and how smoothly it gets to the engine, here are some very good posts from a fellow member in another thread explaining it much better than I can.
The best short ram intake you can get is one that draws from a fresh air source, by design accelerates the air flow along its length and resists thermal absorbtion into the air flow. The best short ram intake ever made for the hemi engine is the Legmaker 'Hammer' intake or the old BFI for the trucks.
So, talking about flow velocity: Because of the 'keg style' intake manifold we have, the higher the intake velocity you have entering through the throttle body, the more air you can move into the combustion chambers in the given open intake valve period. The intake manifold takes care of flow acceleration with its active short/long runner settings, but you want to get as much air flowing into the intake manifold as possible.
Since a N/A engine generates vacuum, this is how it moves air into the combustion chamber, by creating a pressure differential between the cylinders and intake manifold. The intake manifold must replenish its volume regularly and it does this through an intake, and is throttled by the throttle body. The speed at which the manifold replenishes its volume determines its efficiency. An ideal intake tube design reduces the flow restrictions, surface drag, and allows for laminar air compression along its length.
An ideal intake will have a large opening to atmosphere, preferably with no intake restriction (not practical since we want filtration as well), gently reduces its diameter through a cone shape that will allow for the compression of the air flow, which increases velocity of the flow, and made of an internal surface that reduces the effect of the no-slip condition. Smooth surfaces are not ideal, a contoured surface that reduces the detachment and shear away speeds is best.
Most Cold Air Intakes are just that... they route air from outside the engine bay through a tube to the throttle body. As stated in previous posts, the Vararam does this very well, but it doesn't do anything for the flow velocity as there is no runner length to increase the intake velocity. It does have a much larger reservoir capacity compared to most cone filters, but the tiny hole it has to move air through doesn't impress me at all.
Actually, a short ram intake will always give you better flow, it's a characteristic of their design. Intake air temps aren't the same as the ambient air temp except at highway speeds in the short ram intake design because of heat soak. It's a minimal change, <10 deg, but a change none the less.
The Vararam just gets closer to ambient intake temps because it's a shorter travel distance and you see less heat soak into the intake air pocket compared to most short ram CAIs that use a plastic or aluminum mid-tube. If you want the best mid-tube heat characteristics you want to look at a carbon fiber tube, they don't heat soak and don't pass that heat into the intake air charge.
hope this helps you all get the benefits of SRI's
sales@revelperformance.com
Old 11-19-2013, 01:54 AM
calvinmx48 calvinmx48 is offline
Vehicle: 2014 sport CC
Trim Level: sport
Rep:16
calvinmx48 is on a distinguished road
Default Macc08
Macc08- I haven't gotten my final quote shipped to Canada yet. I will have it today
Sounds like we should get two and split shipping
Hemi fever tuned Trinity, bilsteins @ 2.8, 1" TGC spacer, LMI SRI, 180 T-stat, 2500/3500 flares, weather techs, heart-throbe muffler kit, BT catch can, 5K HIDs, on the way- black rhino glamis wheels wrapped in nitto trails
Old 11-19-2013, 01:43 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
great info, thanks!
also, is there any support for the intake (physically) or is the weight of the intake/filter just depending on the clamp to the throttle body? i'd like to see some kind of support bracket for the tube...
Sponsored by:
Old 11-19-2013, 02:31 PM
RAMESPY24's Avatar
RAMESPY24 RAMESPY24 is offline
Vehicle: 2014 dodge ram
Rep:18
RAMESPY24 is on a distinguished road
So the LMI Short Ram CAI will fit our 2014's?
LMI Short Ram Intake, Diablo Sport Trinity w/ 93 Hemifever tune, Retrax Pro Cover, Stubby Antenna, Deeze Tailgate Assist and Moroso Gloss Black Oil Catch Can, tint, and blacked out emblems. Spintech 6000 pro street muffler with Flowmaster Y-pipe .
Old 11-19-2013, 03:07 PM
Trim Level: sport
Rep:16
Default Yes
From what I'm being told yes it will
Old 11-19-2013, 03:22 PM
RAMESPY24's Avatar
Rep:18
Thank you for you kinda and quick response
Old 11-20-2013, 04:07 PM
okcrt okcrt is offline
Vehicle: 2014 Ram R/T
Rep:42
okcrt is on a distinguished road
Which one of these would be best for my 2014 R/T?? It looked like there's 3 options.
http://www.modernmuscleperformance.c..._Air_s/161.htm
Old 11-21-2013, 12:12 AM
macc08's Avatar
Rep:722
lol i wish i could right now. but i am very curious to see how it works out. i havent really seen to many threads with reviews on it.
Sponsored by:
Old 11-21-2013, 08:01 AM
Trim Level: sport
Rep:16
Default Sri
Well I will update when I put it on. It should be here earlie next week
Old 11-22-2013, 01:04 AM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
great info, thanks!
The intake tube is very very light (as it is 100% carbon fiber w/ the exception of the coupling and clamps) and then the weight of the filter, the entire set up can't weigh more than a couple pounds, the only support is the clamp on the TB like many other SRI.
They should fit the 14's just fine
You would be correct!
I do not see any of the RAM intakes on there, the only one from LMI that is confirmed working ATM is this one http://bullysperformance.com/lmi-sho...3-5-7-564.html (which I do not see on the page you provided), and then there is just the tube which should work but I have not seen anyone install it yet http://bullysperformance.com/lmi-mid...3-5-7-565.html.
If you need one of these shipped out feel free to grab one up, if you find a lower price we will match it or beat it
