tonneaucovered.com
Old 11-24-2013, 01:54 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
^^^^ That is the look I'm looking for, just some cool light behind the grill. I'd like to change the head lights to projectors or HIDs to give me more light while driving. I believe it's not legal to have the behind the grill lights on while driving.
I haven't had any problems yet and police see my truck all the time. I believe if it is red or pure blue then it could be a problem, but because my grill lights are a white/blue that there is nothing wrong with it. I made a thread on how to do it if your interested and don't feel like waiting. I don't know exactly where it would mount on the 4th gens as with the 3rd the grill pops up with the hood to make it easy.
That's an awesome shot, Brandon. It does make the truck look alive.
Thanks a lot
Originally Posted by LowUFO View Post
Yeah, very cool Brandon.
Thanks Simon
IG:@briley59
Old 11-24-2013, 07:57 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
Where I'm at you just cant have Front facing LEDS, so as i take that, you just cant see the strip. I assume red and blue is a no no as well. But its probably different in Canada!
Green Interior LEDs
Old 11-24-2013, 08:24 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Very sweet setup, nice install, looks real good in the picture, must be even better in person.
Old 06-06-2014, 01:58 PM
acnrupert acnrupert is offline
Vehicle: 2014 Ram 1500
Trim Level: Tradesman/Express
Rep:19
acnrupert is on a distinguished road
I hate to revive an old thread, but I did this in my truck a few weeks ago with some green led strip that I had leftover from doing the lights under the door.
However, I've run into a problem. For the first couple weeks after I installed everything, it worked great. Then one day they quit working along with the led strip on the drivers side. They both share a ground, but other than that, they are completely separate. The weird thing is that I twisted the wires around on the ground bolt and all of the sudden the side lights popped back on.
Did some quick inspections and discovered that the fuse had blown for the grill lights. I went ahead and switched from a 10amp to a 15amp fuse and tried them again, but no luck and after I hit the switch, once again the side lights went out. Moved the ground wires again and the side came back on, but still no dice on the grill lights. I checked the fuse, and it was fine, however the lights never worked in the front.
Yesterday I was looking around and happened to check the fuse again and now the 15amp fuse was blown even though I hadn't tried flipping the switch anymore since the last time I had checked it.
I'm really not sure what the problem is here. Prior to the first blown fuse, the lights in the grill had been working great for a couple weeks. I'm pretty much an electrical novice, but my understanding is that it was fine for these to share a ground, but I guess my next move is to attach the grill lights to their own ground. After that, I'm not sure what else could be the problem, or why it is that the lights worked for a while and now they won't work at all.
Did you happen to run into any issues close to this while you were doing yours?
Here are some pics of when it was working:
Old 06-08-2014, 11:43 PM
Trim Level: SXT 4x4
Rep:2826
It sounds like a bad ground. I had the ground go bad where I just took the screw out and put a new connector like this.
Just make sure the wire is clean and the area you are grounding to is clean, I usually lightly sand the area I am grounding to to make sure paint or nothing else can interfere.
It may also be where the wire is saudered to the led bar has gone bad.
Test the ground first though, it sounds like this could be your problem. Report back with your results and we will go from there
IG:@briley59
Old 06-15-2014, 04:13 PM
HammerHead's Avatar
HammerHead HammerHead is offline
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
HammerHead is on a distinguished road
I bought some expanded metal & some drywall corner bead & made a bug screen for my '09
the '09 hood lifts up without the grille though, i have seen a 2004 Ram that a friend made up for his bug screen, his hood & grille lift up together
after one trip into the desert
after a quick cleaning
what it looks like installed
That's sweet. What are the dimensions of that mod?
Geared-Tuned 14.0@96
Proud member of the 4 second club...
Old 06-15-2014, 05:25 PM
Trim Level: SXT 4x4
Rep:2826
I really have to do the mod that GT did.
IG:@briley59
Old 06-15-2014, 07:03 PM
HammerHead's Avatar
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
Me too, the simplicity of the design is what I like.
Old 06-16-2014, 12:19 AM
Trim Level: SXT 4x4
Rep:2826
I agree, I think I would need a bigger sheet though because I would wanna cover the A/C rad, tranny cooler and all that stuff.
IG:@briley59
Old 06-21-2014, 02:58 PM
iveyusmc iveyusmc is offline
Vehicle: 2006 Ram 1500
Trim Level: Texas Edition
Rep:12
iveyusmc is on a distinguished road
I like how the grille lights up
